Ethernet Products
5782 Discussions
configuring external SFP through I2C
AJ6
Hai every one ,
I am using inter I350chip and connecting to copper SFP modules how to enter the values of the registors of PHY inside the SFP through I2C is there any software available with intel foe this
thanks and regards
AGXIN.J
st4
New Contributor III
Hi AGXINXAVIER,
Thank you for the post,Which i350 ethernet controller you are using https://www-ssl.intel.com/content/www/us/en/embedded/products/networking/ethernet-controller-i350-family.html Intel® Ethernet Controller I350 Family?
thanks,
wb
AJ6
Dear sir
we are using L2A3341A1-BH-DB -256FBGA controller ,the controller is connected to the processor through a PCIE link and the controller is connected to an external SFP(SFP-1GBT-05) module in customer board (the phy used in SFP Module is http://community.broadcom.com/thread/4225?sr=inbox&ru=16519 BCM54616S) the external phy is connected through an I2C to I350 How to program the eprom connected to the external phy through this I2C line .do you have hex file with settings made for configuring the external phy by enabling the registers appropriate for connecting external I2C and writing the register value recomended by for copper sfp through this I2C .Is there any application with you for writing values into the sfp registers though I2C from PHY Through an application running in processor
thanks and regards
AGXIN.J
st4
New Contributor III
Hi AGXINJ,
Thank you for the post, Correct me if I am wrong, you have another post at , are you referring to the same issue??
thanks,
wb
