Hi.
I am having problems with 82574L
Hardware :
03:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
04:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
05:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
06:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
System:
Centos 7.3 kernel:3.10.0-514.el7.x86_64
Output from message
Feb 26 20:50:02 localhost kernel: e1000e: slot0_GE4 NIC Link is Down
Feb 26 20:50:02 localhost kernel: e1000e: slot0_GE4 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
Feb 26 22:10:02 localhost kernel: e1000e: slot0_GE4 NIC Link is Down
Feb 26 22:10:04 localhost kernel: e1000e: slot0_GE4 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
Feb 26 22:40:02 localhost kernel: e1000e: slot0_GE4 NIC Link is Down
Feb 26 22:40:02 localhost kernel: e1000e: slot0_GE4 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
Feb 26 23:20:02 localhost kernel: e1000e: slot0_GE4 NIC Link is Down
Feb 26 23:20:02 localhost kernel: e1000e: slot0_GE4 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
Feb 26 23:30:02 localhost kernel: e1000e: slot0_GE2 NIC Link is Down
Feb 26 23:30:02 localhost kernel: e1000e: slot0_GE2 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
Feb 27 01:10:02 localhost kernel: e1000e: slot0_GE4 NIC Link is Down
Feb 27 01:10:04 localhost kernel: e1000e: slot0_GE4 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
Feb 27 03:10:02 localhost kernel: e1000e: slot0_GE4 NIC Link is Down
Feb 27 03:10:02 localhost kernel: e1000e: slot0_GE4 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
modinfo
filename: /lib/modules/3.10.0-514.el7.x86_64/updates/drivers/net/ethernet/intel/e1000e/e1000e.ko
version: 3.3.6-NAPI
license: GPL
description: Intel(R) PRO/1000 Network Driver
author: Intel Corporation, <</span>mailto:linux.nics@intel.com linux.nics@intel.com>
rhelversion: 7.3
srcversion: 6453212B70344504D53DE09
alias: pci:v00008086d0000105Esv*sd*bc*sc*i*
depends: ptp
vermagic: 3.10.0-514.el7.x86_64 SMP mod_unload modversions
parm: copybreak:Maximum size of packet that is copied to a new buffer on receive (uint)
parm: TxIntDelay:Transmit Interrupt Delay (array of int)
parm: TxAbsIntDelay:Transmit Absolute Interrupt Delay (array of int)
parm: RxIntDelay:Receive Interrupt Delay (array of int)
parm: RxAbsIntDelay:Receive Absolute Interrupt Delay (array of int)
parm: InterruptThrottleRate:Interrupt Throttling Rate (array of int)
parm: IntMode:Interrupt Mode (array of int)
parm: SmartPowerDownEnable:Enable PHY smart power down (array of int)
parm: KumeranLockLoss:Enable Kumeran lock loss workaround (array of int)
parm: CrcStripping:Enable CRC Stripping, disable if your BMC needs the CRC (array of int)
parm: EEE:Enable/disable on parts that support the feature (array of int)
parm: Node:[ROUTING] Node to allocate memory on, default -1 (array of int)
parm: debug:Debug level (0=none,...,16=all) (int)
[root@localhost ~]# ethtool -k slot0_GE4
Features for slot0_GE4:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: off [fixed]
tx-checksum-ip-generic: on
tx-checksum-ipv6: off [fixed]
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: off [fixed]
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp6-segmentation: on
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off [fixed]
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
tx-mpls-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off
rx-all: off
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
busy-poll: off [fixed]
tx-sctp-segmentation: off [fixed]
l2-fwd-offload: off [fixed]
hw-tc-offload: off [fixed]
[root@localhost ~]#
- Tags:
- GE
Hi Firmware,
Thank you for posting in Wired Communities. Just to double check:
1) Was there any changes made on the system recently?
2) Have you tried changing the cable to test?
3) What is the brand and model of the system where the 82574L is embedded?
4) Can you check if this command will work for you by configuring IntMode=1,1, you may refer to this link about the issue of 82574L https://communities.intel.com/thread/117293 https://communities.intel.com/thread/117293
Please feel free to update me.
Sharon T
Hi Firmware,
Please feel free to provide the information requested. Thanks.
Sharon T
