Ethernet Products
5821 Discussions
e810 - PTP support on VF
MosheSasson
According to intel® ethernet controller e810 — feature support matrix document (https://www.intel.com/content/www/us/en/content-details/630155/intel-ethernet-controller-e810-feature-support-matrix.html) on page 16 , "virtualization section"
the feature "IEEE 1588 - Precision Time Protocol (PTP) support in VF" is marked as supported since version 26.4   (no limitation)
I have been trying to use this feature, but could never get HW timestamping capabilities on VF (using: ethtool -T ...)
- was anyone able to use this feature?
- are there any know limitations?
B_Y
Hello @MosheSasson ,
Can you please try to perform clean driver installation and try this link to update Ice Linux Base driver for the E810 series device.
https://www.intel.com/content/www/us/en/download/19630/intel-network-adapter-driver-for-e810-series-devices-under-linux.html
And also together I'm sending you another link refer Adapter User Guide for Intel® Ethernet Adapters page# 73:
https://www.intel.com/content/www/us/en/download/19373/adapter-user-guide-for-intel-ethernet-adapters.html
IEEE1588/PTP FAQ:
https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ieee1588-faq.pdf
If you have any further questions or queries, please kindly let us know by sharing the output error or screenshot of the things that not working.
BY_Intel
Intel Customer Support
B_Y
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know. Thank you.
BY_Intel
MosheSasson
Hello B_Y,
Thank you for your answer, I also realized that I'm missing some information: I'm using a Linux VM guest (kernel rt 5.15), hosted on VMware ESXi 8.0U2. I'm using the latest ESXi drivers for Ice according to VMware compatibility matrix.
When I pass PF as passthrough to the VM, there is no problem, I'm able to use hardware time stamping.
Problem occurs when passing VF to the VM, and only software time stamping is applicable.
tried to update the ice and iavf drivers in my VM , but I did not see any change in behavior, VF still does not have hardware time stamping ability.
Regarding page 73, the "Adapter User guide" , as I understand PROset is a control program for Windows, so use of it is not relevant for me.
Moshe Sasson
B_Y
The E810 can support PTPv2.1 version.
Perhaps, we need following information to investigate further, thank you in advance:
- At a command prompt type and attach its output here:
a) "ethtool -T <eth port>", where <eth port> is the port identifier
b) "ethtool -i <eth port>"
- SSU log: Help Guide for the Intel® System Support UtilityDownload the Intel® System Support Utility for Linux* operating system
- Any other log showing the error
BY_Intel
B_Y
Greetings.
Sorry just a gentle reminder on if you can provide the requested info from previous post.
Thank you.
BY_Intel
B_Y
Please be informed that we will now close this request since we haven't received any response from our previous follow up. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
BY_Intel
