Ethernet Products
5736 Discussions
how too enable 1 pps in XXV710-DA2T
MHershkovitz
hello.
We tried to enable PPS out in this NIC: INTEL ETHERNET ADAPTER XXV710-DA2T
there is no signal.
how to configure the signal to be enabled?
driver: i40e
version: 4.18.0-305.3.1.el8.x86_64
firmware-version: 7.30 0x800083ad 1.2684.0
expansion-rom-version:
bus-info: 0000:01:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
MHershkovitz
PBA number is : K60938-006
kharo22
Hello
Did you get any clue answer to your issue ?
Karim
