Ethernet Products
5034 Discussions
i210 Ethernet controller linux driver for 1000Base-Kx
AT82
We are planning to use the i210-IS Ethernet controller for 1000Base-kx implementation. Intel provided a Linux driver, but we are not sure if it supports the 1000Base-kx or requires modification.
Could you please confirm if the provided driver below supports 1000Base-KX?
https://github.com/nxp-imx/linux-imx/tree/lf-6.1.55-2.2.0/drivers/net/ethernet/intel/igb
Fikri_Intel
Hi AT82,
Thank you for reaching Intel Community.
Based on your inquiry, you may check the driver at the below link:
Intel Complete Package Link: https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
SourceForge Link: https://sourceforge.net/projects/e1000/files/
Kindly let us know if you require further info.
Fikri_Intel
AT82
Fikri_Intel,
Thanks for the quick response, but does the driver supports a 1000Base-kx?
Fikri_Intel
Hi AT82,
Based on the I210 datasheet, this model supports the 1000Base-KX feature. Hence, the driver package should be included with the 1000Base-kx feature.
You can find the datasheet and specification update link below:
Datasheet: https://www.intel.com/content/www/us/en/content-details/333016/intel-ethernet-controller-i210-datasheet.html?wapkw=I210-IS%20datasheet&DocID=333016
Spec Update: https://cdrdv2.intel.com/v1/dl/getContent/332763
Fikri_Intel
Fikri_Intel
Hi AT82,
Good day!
Just wanted to follow up with you, do you require nay furhter information?
Fikri_Intel
Fikri_Intel
Hi AT82,
Hope you are doing well.
Just wanted to check with you, if you require further information.
If no, please let us know if are good to close this case.
Fikri_Intel
Fikri_Intel
Hi AT82,
This is regarding your inquiry above.
Since we have not seen an update, we will be closing this forum case from our end.
Fikri_Intel
AT82
Sorry for the late reply. I'll post a new thread for a follow up question.
