Ethernet Products
5820 Discussions
i210 always training to 100Mbs.
Ian_m
We have a COMe PC based carrier board, we have designed, that has two i210 ethernet controllers.
We have successfully programmed these devices (NVM & EEPROM) with MAC address and PCIe ID's and are seen correctly and work in Windows 10.
However both controllers always, about 10 seconds after a network cable is plugged in, end up running at 100Mbs. The smart switch at the other end of the cable indicates the i210's are only advertising a max speed of 100Mbs.
We have copied our EEPROM & NVM code to a PCIe i210 add in card (on same system) and when connected connects almost instantly at 1Gbs.
1. Are there any diagnostics/registers/logs we can observe on the i210 (using Lanconfw64) to see why it ends up at 100Mbs.
2. Could it be a PCB &/or circuit design error ?
Ian
IntelSupport
Community Manager
Hi lan_m,
Kindly check this Intel® Ethernet Controller I210 Datasheet.
In order for us to investigate further, please provide the information below:
- Your operating system(OS) and build version
- Is it an integrated I210 or an I210 card purchased separately?
- If separately: Please provide us the Serial Number and Part Number as well as Front and Back Picture or i210
- Please provide us the SSU Logs by checking on the Help Guide for the Intel® System Support Utility
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
Hayat
Intel Customer Support
Ian_m
The operating system is Windows 10 21H2 build 19044.3570.
This is an integrated i210 we have designed onto a board with a plug in processor module (COM express module).
Attached is a picture of the i210 on the board and System Info from Intel System Support Utility.
Kind regards
Ian
Updated System info with both i210's connected.
IntelSupport
Community Manager
Hello lan_m,
Upon checking, we highly advised you to please post a question on Embedded Connectivity Community forum.
If you have any further questions or queries, please kindly let us know.
Else if none, please confirm the closure of this thread once you have posted in the Embedded Connectivity Community Forum.
Thank You
Hayat
IntelSupport
Community Manager
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply here to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank You.
Hayat
Intel® Customer Support
IntelSupport
Community Manager
Thank You.
Hayat
IntelSupport
Community Manager
Hello Ian_m,
Since there are no further response, we will proceed to close the thread.
Kindly open a new thread if you have further question.
Thank You.
Hayat
