Ethernet Products
5506 Discussions
i210 bridging interface problem
I am developer on Linux system. I have develop network tunnel with bridging interface. I found problem in throughput performance. It looks like serial packet. From bandwidth monitoring, i can see packet flow from eth0 to eth1 as serialize not pararell. It need traffic from eth0 down to lowest then eth1 raise the traffic forward.
How can i fix this problem? I have been looking in Interrupt Throttle Rate (ITR) from your guide in "Tuning Throughput Performance for Intel® Ethernet Adapters". But it does not any effect.
Thank you,
suchot
Hi Suchot,
Thank you for the post. What is the network adapter you used here?
Just to double check if you are referring to the information on this website about the tuning
https://wiki.chipp.ch/twiki/pub/CmsTier3/NodeTypeFileServerHPDL380G7/ols2009-pages-169-1842.pdf
wb
Hi wb,
I have been testing with APU2b4 (http://pcengines.ch/apu2b4.htm PC Engines apu2b4 product file ). It use i210AT. From orignal debian wheezy (7.5) use kernel 3.2.0 with intel driver 5.0.5-k (igb). I found problem in LSO packet. Then, i have been use your driver 5.3.5.3 with CFLAGS_EXTRA="-DNO_PTP_SUPPORT -DIGB_NO_LRO -DIGB_PROCFS -DDISABLE_PACKET_SPLIT". After this compiled, my traffic is look work except throughput.
suchot
Hi suchot,
Thank you for the reply, I will try check on this.
thanks,
wb
Hi Suchot,
Just to double check so the problem now is the packet will flow from eth0 to eth1 as serialize but not pararell (which you want to achieve). Please elaborate more the problem. thanks.
rgds,
wb
Hi Wb,
That right, it flow as serialize. As i use "bwm-ng" to monitoring every interface. It shown that the traffic flow from eth0 will be increase, then it decrease when eth1 is increasing.
suchot
Hi Suchot,
Thank you for the information.
rgds,
wb
Hi Wb,
picture below is bandwidth monitoring. At first picture, it shows the traffic put into Eth1 interface. Last picture, it show the traffic pass through Eth0 interface.
Hope this will help you to understand the problem.
Suchot
(Virus scan in progress ...)
Hi Suchot,
Thank you for the additional information.
rgds,
wb
Hi Suchot,
Good day. Further checking, this appear to be not our NIC problem but more on your application.This is a problem with the bridge/tunnel configuration, not the NIC. You may check with your application. Hope this clarified.
rgds,
wb
Hi Wb,
This is not clarified for me. We have been test our system with APU1 (realtek NIC). it works perfectly. We just change from APU1 to APU2. The different is your NIC driver. Hope you understand the problem.
suchot
Hi Suchot,
Thank you for the clarification. Let me further check.
rgds,
wb
Hi Suchot,
Further checking you will need to to edit the driver for your specific needs. You
If you are using our Linux driver, then you can refer to the documentation
Refer to sourceforge documentation if you are using the driver from sourceforge.
wb
Hi Suchot,
Just checking if further assistance needed.
rgds,
wb
