Ethernet Products
4874 Discussions
i210 is not detected as ethernet port even after successful programming using eeprom access tool
Dileep
I created a custom board for Jetson TX2 with i210. I successfully
flashed iNVM using EEPROM access tool. But the device is not detected by
ethernet driver in Jetson TX2. igb driver is showing mac address error.
When I connected the sam jetson to a development board by auvidea it is
working fine. The development board has both iNVM and flash. I haven't
provided a flash for i210 in the design. Is there any possibility that
any connection is missing or additional driver is required for this?
Caguicla_Intel
Hello Dileep,
We noticed that you have submitted a ticket thru your local support group and requested to close the ticket. With this, please be informed that we will now proceed with closure as well. If you need any additional information, please submit a new question as this thread will no longer being monitored
May you have an amazing day ahead!
Crisselle C
Intel Customer Support
