Ethernet Products
5736 Discussions
i219 Tx/Rx Queues?
AKirb
I am currently writing a driver for the i219 and tried to access the received data, but I am missing the Receive Descriptor Base Address (RDBAL/RDBAH)?
I couldn't find this information in the datasheet (http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/ethernet-connection-i219-datasheet.pdf http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/ethernet-connection-i219-datasheet.pdf).
Was also looking at the datasheet of the PCH (http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/100-series-chipset-datasheet-vol-2.pdf http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/100-series-chipset-datasheet-vol-2.pdf).
The datasheet of the i217 (http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i217-ethernet-controller-datasheet.pdf http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i217-ethernet-controller-datasheet.pdf ) contains the RDBAL/RDBAH but I am not entirely convinced that these addresses are also correct for the i219.
I really appreciate any help you can provide,
Akir
Hi Akir,
Good day. Further checking you can use the RDBAL/RDBAH of i217 for I219.
wb
Hi Akir,
Thank you for the post. Let me check for you.
rgds,
wb
Hi Akir,
wb
Hi Akir,
Good day. Please feel free to update me if further assistance needed.
Rgds,
wb
