Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
851 Discussions
i225-IT under Linux with igc driver: kernel message "(unnamed net_device) (uninitialized): PHC"
mmg
Hi everyone,
we have developed a custom NIC board using the i225-IT Ethernet Controller and so far it works fine under Linux with the igc driver.
However, in the kernel log (via dmesg) we stumbled across this line regarding the i225:
igc 0000:0d:00.0 (unnamed net_device) (uninitialized): PHC
Can you help us determine what this means?
Is this an error, or what does it mean?
Thank you in advance and kind regards,
Marcel
Caguicla_Intel
Hello Marcel,
Since your query involves customized board, please be informed that this will be best answered by our Embedded Connectivity Support team. We will help you to move this post to the designated team for further assistance.
Please feel free to contact us if you need assistance from Ethernet support team.
Crisselle C.
Intel® Customer Support
Jaime_Lizarme
Hello @mmg ,
This message you are referring to comes from the open source driver which is supported by each Linux distributor (not by Intel); I suggest you contact your Linux distributor community support. As an example see this thread from Gentoo forum:
https://forums.gentoo.org/viewtopic-p-8685596.html?sid=f9288b1cc226dd3b03959a38c054bdad
Jaime L.
