Hi there,
Windows version: Windows 10 Pro
Version: 22H2
OS Build: 15063.608
Intel Proset: 28.2.0.2
Network card: Intel I350-AM4 (SuperMicro AOC-SGP-I4)
Driver version: 12.18.13.0
Driver date: 2022/02/21
Hi @BenMannell,
Kindly provide the following information for us to check on your query.
1.) System Support Utility(SSU) log of your system. This will allow us to check your Adapter details and configuration. This would also help us identify if you are using an OEM or retail version of Intel Ethernet Adapter. Kindly refer to the steps below.
a- Go to https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600 and download the software.
b- Open SSU.exe
c- Mark the box "Everything" and then click "Scan".
d- When finished scanning, click "Next".
e- Click on "Save" and attach the file to a post.
2.) May I know if the SuperMicro AOC-SGP-I4 was purchased together as whole system with Dell Optiplex 7090? We need your help to share the markings on front and back of the i350-AM4.
BY_Intel
Intel Customer Support
Hi @BenMannell,
Thank you for sharing the information.
Symptoms like this may due to BIOS/driver bug on motherboard or the NIC itself.
As per checking on the SSU/scan log:
- System: Microsoft Windows 10 Home 10.0.19045 Build 19045 - the OS build version is not the latest but still recommended to update to latest OS package.
Using a windows ISO image from genuine source such as from Microsoft can prevent any further trouble.
- Current Optiplex 7090 Bios is quite recent and there is latest Bios and network driver for I350.
https://www.dell.com/support/home/en-my/product-support/product/optiplex-7090-desktop/drivers
Unfortunately, Intel doesn't have original equipment manufacturer(OEM) firmware of Intel I350-AM4 (SuperMicro AOC-SGP-I4) and the software drivers linked from Intel page are generic versions, and can be used for general purposes. To avoid any potential installation incompatibilities on OEM system, Intel recommends checking with the OEM and use the software provided via system manufacturer.
May I suggest you contact the support folks for the board manufacturer(Dell) and see if this issue has been seen previously and if there is a preliminary fix available for testing compatibility while waiting respond from SuperMicro.
BY_Intel
Thank you for this info and things to try.
I have got a temporary workaround running using multiple USB-Ethernet adapters (!) while I focus on some other higher priority jobs. When I come back to re-look at this issue, I'll update this thread with anything help I find.
Hi @BenMannell,
We are apologize as unable to resolve this issue immediately and require help from the manufacturer.
May I know if you wish to keep this thread active ?
You can always post a new question if you may have any other inquiry in the future.
BY_Intel
Hi @BenMannell,
Please be informed that we will now close this request. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
BY_Intel
