Ethernet Products
i350 "V2"
TTris2
There appear to be "V2" 1350 NICs available now, eg:
http://www.amazon.com/Intel-I350T2V2-I350-T2V2-ETHERNET-SERVER/dp/B00MQP1I30 Amazon.com: Intel I350T2V2 I350-T2V2 ETHERNET SERVER ADAP RETAIL UNIT: Computers & Accessories
What was the revision for? Does it have anything to do with the intermittent problem I've been having with my i350-T2 (purchased before V2), where the NIC will disappear upon system reboot?
st4
New Contributor III
Hi Sauntache,
Thank you for the post. So far we do not have information that i350-T2V2 is the revision for the intermittent problem of i350-T2.
I will further check on this.
rgds,
wb
st4
New Contributor III
Hi Sauntache,
Further checking, the change is to accommodate an AUX power component change which enables a decrease of in-rush current during power supply start-up, there is no change in the functionality.
With regards to the intermittent issue, you may try upgrading to latest driver https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3395 https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3395
thanks,
wb
