I am trying to install the driver for X710 card. I am using the driver version "i40e-2.27.8". When running the command "make install", I get the following issue:
~/Desktop/i40e-2.27.8/src$ sudo make install
*** The target kernel has CONFIG_MODULE_SIG_ALL enabled, but
*** the signing key cannot be found. Module signing has been
*** disabled for this build.
make[1]: Entering directory '/usr/src/linux-headers-6.11.0-21-generic'
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
You are using: gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
make[1]: Leaving directory '/usr/src/linux-headers-6.11.0-21-generic'
Installing modules...
INSTALL /lib/modules/6.11.0-21-generic/updates/drivers/net/ethernet/intel/i40e/i40e.ko
DEPMOD /lib/modules/6.11.0-21-generic
Warning: modules_install: missing 'System.map' file. Skipping depmod.
make auxiliary_install
make[1]: Entering directory '/home/marwan/Desktop/i40e-2.27.8/src'
Installing auxiliary...
make[1]: Leaving directory '/home/marwan/Desktop/i40e-2.27.8/src'
/sbin/depmod -e -F /boot/System.map-6.11.0-21-generic -a 6.11.0-21-generic
Updating initramfs...
update-initramfs: Generating /boot/initrd.img-6.11.0-21-generic
make mandocs_install
Copying manpages...
Could you please help to figure out and solve this issue?
many thanks in advance,
Marwan
Hi mhammouda,
Greetings!
Thank you for posting in Intel community forum!
Apologies for the delay in response regarding this matter.
Kindly confirm whether the reported issue is resolved or if you need further assistance.
Meanwhile, kindly share below details to check further.
- Complete model name of the Ethernet card.
- System information that you are using.
Thank you for understanding.
Sreelakshmi
Hi mhammouda,
Greetings!
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
Sreelakshmi
Hello Sreelakshmi,
thanks for your replies,
I tried to solve the issues intensively using many solutions I found online, but nothing worked. I then only physically unplugged the X710 card and then plugged it again, and it worked without the need to update the driver!
So, we can set this issue as resolved,
thanks and best regards,
Marwan
Hi mhammouda,
Greetings!
Thank you for sharing the update. We are glad to hear that the issue has been resolved.
We will proceed to close the request.
Please feel free to reach out if you have any other questions or need additional help in the future.
Sreelakshmi
