Ethernet Products
5741 Discussions
i40e Device not receiving packets with certain VLAN
SantoshSingh
We are using the following Ethernet NIC in pour server -
d8:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
d8:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
d8:00.2 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
d8:00.3 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
This issue we are facing is, for certain VLAN IDs the NIC is not forwarding the packets to the right interface, in fact its not being accepted by the NIC.
Using the "ethtool" we are able to verify that the packets are reaching the NIC and the below stats confirm that.
port.rx_unicast: 69971989. >>>> This counter gets incremented.
But the following counter is NOT being incremented -
rx_packets: 80120521 >>>>>> This counter does NOT gets incremented.
Note that we are seeing this issue with the latest driver upgrade and are unable to find out where the packets are getting dropped.
Can someone help with debugging this further?
Santosh
B_Y
Hi @SantoshSingh,
We also wish to gather some information below for further checking:
1) The model of your server and OS build
2) Did you encounter this issue previously or this is the first time?
3) Do the NIC or network adapter shown any error / unusual symbol?
4) We need your help to gather the System Support Utility logs, steps as following:
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
We'll be waiting for your response.
BY_Intel
Intel Customer Support
B_Y
Hi @SantoshSingh,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know. Thank you.
BY_Intel
B_Y
Hi @SantoshSingh,
Please be informed that we will now close this request since we haven't received any response from our previous follow ups.
Regarding your inquiry, we advise you to contact our developer at embedded communities. You can ask more detailed questions using that community's post, which will help.
Embedded Connectivity Forum:
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
BY_Intel
