Ethernet Products
5770 Discussions
i40e MAC filter hash state failed
SantoshSingh
My NIC is dropping the packets destined to the following MAC and VLAN ID.
I got the following error from the driver when i tried to dump the mac filter hash state in NIC.
[3214997.759285] i40e 0000:19:00.3:     mac_filter_hash: 33:33:ff:43:75:3c vid=2056, state FAILED
[3214997.759293] i40e 0000:19:00.3:     mac_filter_hash: 33:33:ff:43:75:3c vid=2200, state FAILED
[3214997.759300] i40e 0000:19:00.3:     active_filters 1946, promisc_threshold 1974, overflow promisc ON
Using the "ethtool" I could confirm that the device is receiving the packets, but not sending it to upper layers.
port.rx_unicast >>>> This counter is incrementing
Has someone seen similar issue before?
Does this means that we are reaching the scale limit in terms of number of hash entries?
What does the "active_filters" and "promisc_threshold" means?
Thanks & Regards,
Santosh
B_Y
Hi @SantoshSingh,
Kindly provide the following information for us to check on your query:
1) Please advise if you are using custom board or with Intel/OEM system board?
2) Please provide the Intel(R) network adapter involved
3) Linux distribution
4) Ethtool -i
5) Ethtool -k or sudo ethtool -k <interface_name>
Thank you.
BY_Intel
Intel Customer Support
SantoshSingh
Thank you for your response.
Below is the data.
Cisco UCS Server.
b1:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
b1:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
b1:00.2 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
b1:00.3 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
Linux 5.4.0-139-generic #156-Ubuntu SMP Fri Jan 20 17:27:18 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
4) Ethtool -i
root@sonic-ucs-m6-2:/home/tester# ethtool -i ens108f0
driver: i40e
version: 2.16.11
firmware-version: 5.05 0x80002b50 0.385.8
expansion-rom-version:
bus-info: 0000:b1:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
root@sonic-ucs-m6-2:/home/tester# ethtool -k ens108f0
Features for ens108f0:
rx-checksumming: off
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: on
tx-tcp-mangleid-segmentation: off
tx-tcp6-segmentation: on
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: on
receive-hashing: on
highdma: on
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: on
tx-gre-csum-segmentation: on
tx-ipxip4-segmentation: on
tx-ipxip6-segmentation: on
tx-udp_tnl-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
B_Y
Hi @SantoshSingh,
Thank you for sharing the information.
Firstly, based on the network adapter/controller shown, may I clarify with you if it is embedded to Cisco UCS' system board?
Secondly, the i40e driver and linux kernel version are not up to date. May I know if you have tried update to later version if it makes some differences?
Thank you.
BY_Intel
SantoshSingh
Hi @BY_Intel,
Thanks for your reply.
    Yes
    We started seeing this issue with a driver upgrade, can you please point me to the latest version of the driver?
What is the scale Limit, in terms of number of Entries in MAC FILTER HASH Table?
Also, any Idea on the below message -
Thanks & Regards,
Santosh
B_Y
Hi @SantoshSingh,
Thank you for your quick response.
Since this question related to embedded configuration, may I suggest to post inside Intel Embedded Communities and link as below.
Embedded Connectivity Forum:
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Thank you.
BY_Intel
B_Y
Hi @SantoshSingh,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know. You may refer the latest i40e driver at https://www.intel.com/content/www/us/en/download/18026/intel-network-adapter-driver-for-pcie-40-gigabit-ethernet-network-connections-under-linux.html
Thank you.
Thank you.
BY_Intel
B_Y
Hi @SantoshSingh,
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
BY_Intel
