Ethernet Products
5531 Discussions
i40e nics are down when we use them on Dual CPU
WL
Hi All,
When we use netperf to generate traffic, i40e nics are down very soon(
the throughput is about 76Gbps).
CPU: "Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz" X2
TOPO:
port5, port6, port11, port12 are i40e interfaces.
port6 and port12 are in a net namespace.
port5<--->port6: port5 is connected port6 directly.
port11<--->port12: port11 is connected port12 directly.
nics interrupt bind cpu:
port5: 0, 1, 2, 3, 4 (CPU0)
port6: 10, 11, 12, 13, 14 (CPU1)
port11: 5, 6, 7, 8, 9(CPU0)
port12: 15, 16, 17, 18, 19 (CPU1)
kernel: 3.13.11
driver: i40e stable
1.0.15(http://sourceforge.net/projects/e1000/files/i40e%20stable/1.0.15/ http://sourceforge.net/projects/e1000/files/i40e%20stable/1.0.15/):
version: 1.0.15
firmware-version: f4.1 a1.1 n04.10 e800010e0
bus-info: 0000:09:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
We also tried latest kernel 3.16.3 (with its own driver), it has the same issue.
netperf cmd:
netperf -T 14,19 -L 15.3.2.1 -H 15.3.1.100 -f m -D 1 -l 600 >/dev/null &
netperf -T 13,18 -L 15.5.2.1 -H 15.5.1.100 -f m -D 1 -l 600 >/dev/null &
netperf -T 12,17 -L 15.2.2.1 -H 15.2.1.100 -f m -D 1 -l 600 >/dev/null &
netperf -T 11,16 -L 15.1.2.1 -H 15.1.1.100 -f m -D 1 -l 600 >/dev/null &
netperf -T 10,15 -L 15.4.2.1 -H 15.4.1.100 -f m -D 1 -l 600 >/dev/null &
netperf -T 4,9 -L 14.4.2.1 -H 14.4.1.100 -f m -D 1 -l 600 >/dev/null &
netperf -T 3,8 -L 14.1.2.1 -H 14.1.1.100 -f m -D 1 -l 600 >/dev/null &
netperf -T 2,7 -L 14.5.2.1 -H 14.5.1.100 -f m -D 1 -l 600 >/dev/null &
netperf -T 1,6 -L 14.2.2.1 -H 14.2.1.100 -f m -D 1 -l 600 >/dev/null &
netperf -T 0,5 -L 14.3.2.1 -H 14.3.1.100 -f m -D 1 -l 600 >/dev/null &
dmesg:
i40e 0000:09:00.1 port6: NIC Link is Up 40 Gbps Full Duplex, Flow Control: None
i40e 0000:09:00.0 port5: NIC Link is Up 40 Gbps Full Duplex, Flow Control: None
IPv6: ADDRCONF(NETDEV_CHANGE): port6: link becomes ready
IPv6: ADDRCONF(NETDEV_CHANGE): port5: link becomes ready
i40e 0000:8a:00.0 port11: NIC Link is Up 40 Gbps Full Duplex, Flow Control: None
i40e 0000:8a:00.1 port12: NIC Link is Up 40 Gbps Full Duplex, Flow Control: None
IPv6: ADDRCONF(NETDEV_CHANGE): port11: link becomes ready
IPv6: ADDRCONF(NETDEV_CHANGE): port12: link becomes ready
------------[ cut here ]------------
WARNING: at net/sched/sch_generic.c:254 dev_watchdog+0x174/0x1da()
Hardware name: To be filled by O.E.M.
NETDEV WATCHDOG: port5 (i40e): transmit queue 3 timed out
<span style="color: # 2222...
