Ethernet Products
5821 Discussions
i40evf maximum RSS queues reasoning
SHegd2
I was looking through the i40evf source code, and it seems like the maximum number of queues supported is 4. Is there a reasoning for this? Is there a way to use more, such as 16?
I've seen patches proposing removing a few variables (MAX_QUEUES, which sets the max to 16, but doesn't actually serve a purpose since the RX queues limit is set to 4).
Hi Brokotiv,
Thank you for posting in Wired Communities. Just to double check if you are referring to the driver at
https://downloadcenter.intel.com/download/24693/Intel-Network-Adapter-Virtual-Function-Driver-for-Intel-40-Gigabit-Ethernet-Network-Connections
There is an issue stated in our README file regarding increasing the RSS queue may result in code 10 error, you may find the information at https://downloadmirror.intel.com/24693/eng/readme.txt I have posted here for your reference as well:
" Code 10 Error in Device Manager When Intel DCB Installed and RSS Queues Changed to 16 or Greater
If the Intel DCB feature is installed, changing the number of Receive Side
Scaling (RSS) queues to 16 or greater may result in a Code 10 error in Device
Manager. To resolve this issue, reinstall the driver from the Intel
installation media. Note that this will reset the RSS queues value to the
default of 8. Do not change the RSS queues to 16 or greater, as doing so will
result in another Code 10 error. Setting RSS queues to a lower value such as 1,
2, or 4 does not cause error."
If this is not the driver you refer to, please provide the link where the driver was posted. Thank you.
Sharon T
SHegd2
That is indeed the driver used. I was referring to the code here:
https://github.com/torvalds/linux/blob/master/drivers/net/ethernet/intel/i40evf/i40evf.h# L109 linux/i40evf.h at master · torvalds/linux · GitHub
Is this not accurate as to the latest i40evf driver? When I used SR-IOV with the driver, I was only seeing 4 queues enabled by default, and I was not sure how to increase the maximum, to 8 or 16 as mentioned. Using "ethtool -l" showed a maximum of 4 queues. Is there documentation on how to increase this otherwise?
If it helps, I am running this inside an Ubuntu 14.04 VM, running Linux kernel 4.4.0-97-generic. The host the VM is running on is running on Ubuntu 16.04, with Linux Kernel 4.4.0-87-generic.
Thanks for the help.
Hi Brokotiv,
Thank you for sharing the information. Can you also share what is the exact model of your network adapter so that I can better assist. Thanks.
Sharon T
SHegd2
Hi Sharon,
The NIC is a Ethernet Controller X710 for 10GbE SFP+.
SHegd2
Hi Sharon,
I just wanted to check if you had any updates on this issue.
Hi Brokotiv,
We are still checking and will update in case there is any information to share.
Sharon T
Intel Customer Support
Agent under contract to Intel
Hi Brokotiv,
Can you confirm how many cores/cpus are assigned to the Virtual machine?
Sharon T
SHegd2
Hi Sharon, 36 cores were assigned to the VM.
Hi Brokotiv,
Thank you. We will further check.
Sharon T
Hi Brokotiv,
Hope you don't mind, we need more information below:
  1. Linux kernel log from the host OS
  2. I40e driver version number from the host.
  3. Did customer modified i40e driver?
  4. Linux kernel log from the Guest OS.
  5. I40ef driver version number from the guest.
  6. Did customer modified i40evf driver?
  7. Ubuntu 14.4 VM settings. Number of VCPUS assigned, memory amount assigned, network devices attached, PCI devices attached in pass though mode, etc.
Please provide SSU LOG as some information can be found there. You may visit this link for the SSU tool:
https://downloadcenter.intel.com/product/91600/Intel-System-Support-Utility
Looking forward to you reply. Thank you.
Sharon T
Hi Brokotiv,
Please fee free to provide the requested information.
Sharon T
