Ethernet Products
5566 Discussions
iSCSI with Intel PRO/1000 PT Dual Port Server Adapter
There's a ton of configuration settings here.
Can anyone point me to a best practices guide for optimizing performance with iSCSI on Windows Server 2008 R2?
CPujo
Use Jumbo Packet to 9k
See you later, bye
Ricardo_G_Intel1
deko, Your post has been moved over the networking communities.
st4
New Contributor III
Hi Deko,
Thank you for the post. It depends on the system and setup, what you can try is to tweak the following options:
adjust the Interrupt Moderation, TCP/IP offloading options, Performance option Transmit and Receive buffer
You may refer to this website for more details about each setting
http://www.intel.com/support/network/sb/cs-025841.htm Network Connectivity — Advanced Settings for Intel® Ethernet 10/100 and Gigabit Adapters
Hope this helps.
rgds,
wb
