Ethernet Products
4621 Discussions
identical mac addresses
MattRecycle
hi, I have a bit of a problem with a bunch of HP 840 G3 laptops - they all have identical Mac Addresses! this is at hardware level, viewable within BIOS and running the Intel I219-LM. Windows has not been installed. i can't run the boot flash utility as it says "flash not present" - i'm presuming blocked by HP
HP have been no help at all, I believe they may have been setup this way for a particular customer at manufacturing. does any body have any ideas how I can reset, or alter the Mac address?
many thanks
Mike_Intel
Hello MattRecycle,
Are you trying to update the firmware of the on-board Intel I219-LM using Intel's firmware file?
Let me also ask what is HP's advise on this issue?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel Customer Support Technicians
MattRecycle
hi, thanks for the reply
HP have said they are unable to help, we have almost 70 of these units all with the same Mac Address
strangely enough they also have the same Build ID, and Asset tracking numbers in BIOS
the Intel Flash program isn't working as I believe its blocked/disabled by the HP BIOS
nobody I know in the industry have ever come across a problem like this before
Mike_Intel
Hello MattRecycle,
Thank you for the clarification. And also, let me explain that Intel's firmware update is for Intel retail Ethernet card only.
Each manufacturer has their own firmware update even if the are using Intel chip in the Ethernet card.
In this case, since the card is embedded on the board. Intel firmware update file will not work and the best team that can assist you is HP. I am sorry, but HP has the control over their board and their system.
Michael L.
Mike_Intel
Hello MattRecycle,
I am just checking if you are already talking to HP about the issue.
If you still have clarifications, please tell us.
Michael L.
Mike_Intel
Hello MattRecycle,
I just want to check if you are already talking to HP and I hope that they were able to assist you.
If you need further assistance, please post a new question.
Michael L.
