Ethernet Products
5566 Discussions
igb 0000:07:00.0: The NVM Checksum Is Not Valid
RSrip
I am receiving the follwoing error when I installed the NIC card on HP Server
Please provide troubleshooting steps.
Rahul
Hi Rahul,
Thank you for the post. Can you provide more information for us to better assist on this.
1) What is the exact model of your NIC?
2) What is the exact Linux version?
3) What is the exact Linux* driver version?
4) What is the firmware on your NIC? Have you tried re-flashing the firmware?
wb
RSrip
Hi wb,
1) What is the exact model of NIC?
07:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
Subsystem: Intel Corporation Ethernet Server Adapter I350-T4
CentOS Linux release 7.3.1611 (Core)
Linux 3.10.0-514.2.2.el7.x86_64
modinfo igb
filename: /lib/modules/3.10.0-514.2.2.el7.x86_64/kernel/drivers/net/ethernet/intel/igb/igb.ko
version: 5.3.0-k
license: GPL
description: Intel(R) Gigabit Ethernet Network Driver
author: Intel Corporation, <<a href="mailto:e1000-devel@lists.sourceforge.net" target="_blank">e1000-devel@lists.sourceforge.net>
rhelversion: 7.3
srcversion: FAD286C6DDDCF6F7207E580
I could not find a way to gather this information. The interfaces are listed as "UNCLAIMED" in lshw and do not show a firmware version there. Ethtool doesn't work either as no interface device names are generated for this Card. Is there a way to gather this information?
For re-flashing the firmware, what is the recommended process for this action given that we are running CentOS 7.3? Is there a step-by-step guide?
Hi Rahul,
Thank you for the information. I thought you were using the X710 series that is why I asked for the firmware version. Let me double check then update you.
rgds,
wb
RSrip
Thanks for your reply.
Can you please provide the process to re-flash the firmware
Rahul
Hi Rahul,
Thank you, that is something I need to check as we usually provides the driver. I will double check.
Rgds,
wb
Hi Rahul,
Good day. We only have driver for download at our website, Can you double check with HP* the system vendor for the firmware of the onboard NIC which is integrated on their system.
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006628.html?wapkw=oem+network
wb
RSrip
Hi wb,
Sure, let me check with the HP system vendor regarding the firmware and get back to you.
Rahul
Hi Rahul,
Thanks, please feel free to update me.
rgds,
wb
Hi Rahul,
Good day. Please feel free to update me.
Rgds,
wb
