Ethernet Products
5742 Discussions
implementation of network bonding
AJ6
hi every one
I am using i210 pcie to ethernet chip i am using a pcie switch between intel i7 processor and ethernet controller i210 i have two such controller connected to the pcie switch i was trying to do network bonding or teaming between the two links how to do this i tried this in RHEL but i am unable to do when i remove one link link between the end device is totally failing how to implement this with two links connected to a network switch
SYeo3
Valued Contributor I
Dear AGXIN.XAVIER,
Thank you for contacting Intel.
Please refer to the link below to configure Channel Bonding:
http://www.intel.com/support/network/sb/cs-009747.htm Network Connectivity — How Do I Use Teaming with Intel® Advanced Network Services (Intel® ANS)?
- look for Linux Ethernet Bonding
If you still encounter the same issue, please provide us the details below:
1. Operating System and version:
2. Driver version:
3. Teaming/bonding mode:
4. Steps on how you configure channel bonding
5. Error messages
Hope this helps.
Sincerely,
Sandy
