I'm running Ubuntu18.04 on a motherboard with your Ethernet controller, The Ubuntu kernel is 5.4.10, but the system can't drive the NIC properly, when I use the ifconfig command, there are no ethx NIC numbers.
I tried to access the community's answers, downloaded the file from the link:https://www.intel.cn/content/www/cn/zh/download/15084/intel-ethernet-adapter-complete-driver-pack.html, but I only seem to see the driver installation file for i226-v in /PRO2500, but it only has the windows version.
Do you have a driver for the I226-V Ethernet controller for ubuntu18.04? If you can, please provide me with the direct download link, thank you very much!
I add that when i use command : lspci -nn | grep -i ethernet
it is show that: 01:00.0 Ethernet controller [0200]: Intel Corporation Device [8086:125c] (rev 04),I'm not sure if it's the I226-V
