I am thining of using the intel 82599ES to pull streaming data from two 10 bit A/D running at 200 MHz clock rate so 2G bit rate (plus overhead) per A/D.
I would use a dedicated FPGA to implement the best packet protocol to feed the data.
The card would be used on a Linux system and I am happy to see most of the post are about working with Linux.
Can you provide any comments on this and which protocol would be best to start with?
Hello bstrick,
Greetings for the day!!
Thank you for posting in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and would like to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved, or if you require further assistance from us? Your prompt response will greatly help us in diagnosing and resolving the issue as quickly as possible.
We appreciate your patience and understanding, and we look forward to hearing from you soon.
Kuzhanthai Yesu R
Hello bstrick,
This is to follow up on the issue you reported to us.
Could you please confirm if the issue has been resolved or if you still require our assistance? Your timely response will help us diagnose and address the issue more efficiently.
We look forward to hearing from you soon.
Kuzhanthai Yesu R
Hello bstrick,
This is the final follow-up regarding the issue you reported to us.
Could you please let us know if the issue has been resolved or if you still need our help? Your prompt response will assist us in diagnosing and addressing the issue more effectively.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Please feel free to respond to this email at your earliest convenience.
Kuzhanthai Yesu R
