Ethernet Products
5721 Discussions
intel i219-V (Asrock Z170 Pro4S) performance on windows 10
MMacu
I am having problems with my network performance.
If i leave it's speed at auto negotiation it works on 10 mbps.
if i set it manually on 100 mbps? download works nice but upload is as low as 0.03 mbps or it doesnt work at all, i think depending on driver i use (i checked one from intel and one from Asrock site).
I didnt have any problems prior to upgrading my os to windows 10 and another computer in the network works fine with download of arouind 100 mbps and upload around 40-60 (like it should be).
Any help please? If you need any addtional data regarding drivers or anything that could help identify problems just ask i will provide them ASAP.
AP16
Valued Contributor III
Try to update drivers: https://downloadcenter.intel.com/search?keyword=i218-V Intel® Download Center . Take also a note at https://downloadcenter.intel.com/download/20585/Intel-R-LAN-Driver-82579-I217-and-I218-Link-Negotiation-Process-Parameter-Change-Utility-for-Windows Download Intel(R) LAN Driver 82579, I217, and I218 Link Negotiation Process Parameter Change Utility for Windows
MMacu
did that. Now when i leave it at auto negotiation i have 100mbps download and 0.03 mbps upload.
MMacu
ok i fixed my problem.
Seems like intel ethernet cards is more sensitive to network cable quality. I changed cable to better and now all works fine.
