Is there a switch in the middle, and does it have the proper cableing to the router?
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
also there is no switch and i checked the cables , with no difference.
Greetings Mr. Shahar,
Thank you for contacting Intel Customer Support.
We gather some information from the report that you provided earlier.
Board Model: Gigabyte
System Model: Z690 AERO G
Platform: Desktop
Driver version (current): "2.1.3.3"
OS Name: Microsoft Windows 11 Pro x64bits
You may try to follow this step to change configuration first:
On the ethernet adapter right click -> properties -> configure -> advanced -> speed / duplex ---- changed from Auto to 1.0Gbps
Once complete the steps, please perform clean driver installation.
1. Uninstall the ethernet driver
2. Restart the PC
3. Re-install the latest driver and check the speed.
Link to install the drivers:
https://www.gigabyte.com/Motherboard/Z690-AERO-G-DDR4-rev-1x/support#support-dl-driver-lan
Thank You & Regards
Yogaeasvaran
Intel® Customer Support
dear Yogaeasvaran , i tried changing the speed (only have 2.5gbs half duplex to select ) - didn't help
i uninstalled , restart the PC , and when pc rebotted the driver was already installed with no diffrence, still capped at 100mb for both upload and download (BTW it should be only100 on upload , the download should be 1000mb )
Thanks for the feedback and you have tried all the steps provided by Intel and unfortunately the issue still persist.
Intel® Ethernet Controller is embedded on Original Equipment Manufacturer (OEM) system, it's best to check with the manufacturer as the software drivers linked from Intel page are generic versions and can be used for general purposes.
To avoid any potential installation incompatibilities on OEM system, Intel recommends checking with the OEM and use the software provided via system manufacturer.
Please check with the Gigabyte support to isolate this issue.
Thank You & Regards
Yogaeasvaran
Regarding your case number 05953600, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank You & Regards
Yogaeasvaran
Thank You & Regards
Yogaeasvaran
Regarding your case number 05953600, we are following up 3rd time to find out if you were able to complete the actions, we previously recommended.
Thank You & Regards
Yogaeasvaran
Greetings Shahar,
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Thank You & Regards
Yogaeasvaran
