Ethernet Products
5823 Discussions
intel(r) ethernet connection (7) i219-lm
VMisc
Geräte sind HP EliteDesk 800 G1 - G4​
Hallo
Wir haben hier neue Geräte bekommen mit der Netzkarte
bei den Vorgängermodellen war noch die Karte
Generation (5) oder (4) drin.
Das Problem ist, dass nur die PCs mit der (7) Generation Netzkarte sehr lange brauchen, bis diese eine IP adresse via DHCP Server bezogen haben. Alle anderen (älteren) Generationen der selben Netzkarte machen das Problem nicht.
Wer weiss Rat? Danke
Mike_Intel
Hello VMisc,
Before we proceed, I would like to inform you that we can only support you in English language and we are just using our translator tool to understand your inquiry.
Regarding the issue that you encounter, please provide the following details.
  1. Are you using on-board NIC or a PCIe NIC?
  2. What is your OS?
  3. How long did it take for it to obtain an IP address?
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
VMisc
​Hallo Michael
Danke für die Hilfe
  1. Es ist on-board
  2. Windows10 1809 x64
  3. es braucht 11-15s
Mike_Intel
Hello VMisc,
I am sorry, please reply only in English. We can only support you in English language. Let me gather the following information.
  1. Is it working fine before?
  2. How many systems are affected?
  3. What are the troubleshooting steps that you tried so far?
Michael L.
VMisc
Intel Ethernet Connection (7) l219-LM has never worked properly.
the previous versions Intel Ethernet Connection (5) l219-LM, Intel Ethernet Connection (4) l219-LM are no problem. only the version Intel Ethernet Connection (7) l219-LM only gets an IP after approx. 11s after a restart. This is extremely long. Currently affected are 40 devices.
We have made:
Bios update network card driver update (V.12.18.8.4 and V.12.17.10.7) various test to find out which component is to blame. Fixed IP for testing (problem was fixed, but of course no option for a company)
Mike_Intel
Hello VMisc,
Since it is an on-board NIC. We can only help you try our generic driver which you already tried. At this point, have you tried contacting HP for further assistance since it is embedded on the system?
Michael L.
VMisc
The problem is 100% on the Intel Ethernet Connection (7) l219-LM driver.
Too bad. But I already know the game.
Intel does not handle its products and refers them to HP
HP says its an Intel product, ask Intel.
In the end, nobody helps.
Since you have to really ask if you do not go to Apple.
Thank you
Mike_Intel
Hello VMisc,
I am sorry if you feel that way. I hope you also understand that even if the NIC chip is from Intel, it was embedded on a system as on-board NIC. So the OS compatibility is now being dictated by the board and they may have altered the NIC. We have generic driver that you can try however if the problem is still the same, it is better to consult the manufacturer of the board.
Michael L.
Mike_Intel
Hello VMisc,
I just want to check if you have other questions regarding this issue.
If you do, please let us know.
Michael L.
Mike_Intel
Hello VMisc,
If you still have question or clarifications, please let us know.
Michael L.
