we are trying to install ixgbe-4.3.15.tar.gz driver on ubuntu 14.04 3.13.0-24-generic but we are receiving following error:
Any suggestion to solve the problem?
Thanks and br/
Cristina
/home/master/ixgbe/ixgbe-4.3.15/src# make CFLAGS_EXTRA=-DIXGBE_NO_LRO install
make[1]: Entering directory `/usr/src/linux-headers-3.13.0-24-generic'
CC [M] /home/master/ixgbe/ixgbe-4.3.15/src/ixgbe_main.o
/home/master/ixgbe/ixgbe-4.3.15/src/ixgbe_main.c: In function \u2018ixgbe_select_queue\u2019:
/home/master/ixgbe/ixgbe-4.3.15/src/ixgbe_main.c:8701:3: error: implicit declaration of function \u2018__netdev_pick_tx\u2019 [-Werror=implicit-function-declaration]
return __netdev_pick_tx(dev, skb);
/home/master/ixgbe/ixgbe-4.3.15/src/ixgbe_main.c: At top level:
/home/master/ixgbe/ixgbe-4.3.15/src/ixgbe_main.c:9589:2: warning: initialization from incompatible pointer type [enabled by default]
.ndo_select_queue = ixgbe_select_queue,
/home/master/ixgbe/ixgbe-4.3.15/src/ixgbe_main.c:9589:2: warning: (near initialization for \u2018ixgbe_netdev_ops.ndo_select_queue\u2019) [enabled by default]
cc1: some warnings being treated as errors
make[3]: *** [/home/master/ixgbe/ixgbe-4.3.15/src/ixgbe_main.o] Error 1
make[2]: *** [_module_/home/master/ixgbe/ixgbe-4.3.15/src] Error 2
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-3.13.0-24-generic'
make: *** [default] Error 2
thanks for your answer. Finally yesterday i did the following:
apt-get install linux-generic-lts-utopic
reboot
uname -a
Linux myhost 3.16.0-77-generic # 99~14.04.1-Ubuntu SMP Tue Jun 28 19:17:10 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
After this the compilation was successful.
I didn't try yet to update initramfs.
Hi Cpalomo,
Thank you for the update and sharing the information, glad you were able to complied successfully.
rgds
wb
