I have an 82599 and i want to enable XAUI operation mode.
In the datasheet it's said that it could be forced by software by manipulating AUTOC registers...
Is it possible to manipulate those registers throw a utility ? or should i modify the driver and add a functionnality for this ?
Thank you.
Hello @jackbar13,
1) Please advise if you are using custom board or with which brand/OEM system board?
2) Linux distribution: 6.5-rc3 kernel is working on which Debian Trixie? May I also inquire on which ixgbe drivers that you tested with?
3) Ethtool -i
4) Ethtool -k or sudo ethtool -k <interface_name>
Thank you.
BY_Intel
Intel Customer Support
Hi @B_Y
1) I'm using two Intel PC's (server board) on which both of them have Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection and i want to communicate with FPGA which supports only 8b/10b.
2) I'm using Ubuntu 22.04.2 LTS and ixgbe 5.19.0-46-generic SMP preempt mod_unload modversions (?).
3) driver: ixgbe
version: 5.19.0-46-generic
firmware-version: 0x000118f1
expansion-rom-version:
bus-info: 0000:01:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
4) Features for ens1f1:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: off [fixed]
tx-checksum-ip-generic: on
tx-checksum-ipv6: off [fixed]
tx-checksum-fcoe-crc: on [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp-mangleid-segmentation: off
tx-tcp6-segmentation: on
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: on [fixed]
tx-gre-segmentation: on
tx-gre-csum-segmentation: on
tx-ipxip4-segmentation: on
tx-ipxip6-segmentation: on
tx-udp_tnl-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-tunnel-remcsum-segmentation: off [fixed]
tx-sctp-segmentation: off [fixed]
tx-esp-segmentation: on
tx-udp-segmentation: on
tx-gso-list: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off
hw-tc-offload: off
esp-hw-offload: on
esp-tx-csum-hw-offload: on
rx-udp_tunnel-port-offload: off [fixed]
tls-hw-tx-offload: off [fixed]
tls-hw-rx-offload: off [fixed]
rx-gro-hw: off [fixed]
tls-hw-record: off [fixed]
rx-gro-list: off
macsec-hw-offload: off [fixed]
rx-udp-gro-forwarding: off
hsr-tag-ins-offload: off [fixed]
hsr-tag-rm-offload: off [fixed]
hsr-fwd-offload: off [fixed]
hsr-dup-offload: off [fixed]
Hello @jackbar13,
We appreciate the information. Please give us 1-3 business days to check appropriately. I appreciate your patience.
BY_Intel
Hello @jackbar13,
Thank you for your patience.
After thorough research, we're unable to find the tool to manipulate those registers on Datasheet, page# 110: "3.7.1.1 XAUI Operating Mode"
Normally, Ethernet support representative will suggest user to a dedicated forum for questions on tools and embedded networking connectivity.
Based on the comments at Embedded , it may seem the next direction require registration on Premier account, steps as following: https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
We hope this clarifies matters for you.
BY_Intel
Hello @jackbar13,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know.
Thank you.
BY_Intel
Hello @jackbar13,
Please be informed that we will now close this request as this request most suitable support at embedded networking connectivity forum. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored. Thank you for your understanding.
BY_Intel
