Hi! all
I use 82599EN with 10Gbps SFP module. I measre through put and the result is 1.3Gbps.
I would like to improve through put, so I would like to use MSI-X.
I enter "insmod ixgbe.ko IntMode=2". The result is below,
This driver fail to start because of "Failed to allocate MSI-X interrupts. Err: -28".
~# insmod ixgbe.ko IntMode=2
Intel(R) 10 Gigabit PCI Express Network Driver - version 4.3.15
Copyright (c) 1999-2015 Intel Corporation.
ixgbe: Interrupt Mode set to 2
ixgbe 0000:01:00.0: Failed to allocate MSI-X interrupts. Err: -28
ixgbe 0000:01:00.0: Disabling VMQd support
ixgbe 0000:01:00.0: Disabling RSS support
ixgbe 0000:01:00.0: PCI Express bandwidth of 16GT/s available
ixgbe 0000:01:00.0: (Speed:5.0GT/s, Width: x4, Encoding Loss:20%)
ixgbe 0000:01:00.0 eth2: MAC: 2, PHY: 15, SFP+: 5, PBA No: FFFFFF-0FF
ixgbe 0000:01:00.0: 00:a0:c9:12:34:56
ixgbe 0000:01:00.0 eth2: Enabled Features: RxQ: 1 TxQ: 1
ixgbe 0000:01:00.0 eth2: Intel(R) 10 Gigabit Network Connection
platform leds.7: Driver leds-gpio requests probe deferral
Could you tell the reason which occurs "Failed to allocate MSI-X interrupts. Err: -28" ?
BR,
Taira
Hi Taira,
Thank you for the post. I will check on this, can you also provide below info:
1) what is the brand and model of the fiber optical module use?
2) Is this an onboard NIC 82599EN ? What is the brand and model of your system?
3) Did you install the VF Linux driver
https://downloadcenter.intel.com/download/18700/Network-Adapter-Virtual-Function-Driver-for-10-Gigab...
4) Try run the command 'lspci -v' to show device with MSI or MSI-X capabilities
5) Try run lspci -t' gives the list of bridges. Please check
/sys/bus/pci/devices/*/msi_bus will to find out whether MSIs are enabled or disabled
wb
Hi Taira,
Please feel free to provide information requested on my post.
thanks
wb
Hi! wb
Sorry for my late reply. I answer your quesstions.
The SFP module which I use is FINISAR FTLX8573D3BTL.
Yes. 82599EN is implemented on our original board. The board is not commercial.
https://downloadcenter.intel.com/download/18700/Network-Adapter-Virtual-Function-Driver-for-10-Gigab... https://downloadcenter.intel.com/download/18700/Network-Adapter-Virtual-Function-Driver-for-10-Gigab...
No,I use ixgbe driver, not ixgbevf driver.
I attached the result.
------[begin]------
00:00.0 PCI bridge: Altera Corporation Device e000 (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00000000-00000fff
Memory behind bridge: c0000000-c00fffff
Prefetchable memory behind bridge: 00000000-000fffff
Capabilities: [50] MSI: Enable- Count=1/4 Maskable- 64bit+
Capabilities: [68] MSI-X: Enable- Count=64 Masked-
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Root Port (Slot-), MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [200] Vendor Specific Information: ID=1172 Rev=0 Len=044 <?>
01:00.0 Ethernet controller: Intel Corporation Device 1557 (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 265
Memory at c0000000 (64-bit, non-prefetchable) [size=128K]
I/O ports at [disabled]
Memory at c0020000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable- Count=64 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [e0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number 00-00-00-ff-ff-00-00-00
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Kernel driver in use: ixgbe
------[end]------
lspci -t result:
-[0000:00]---00.0-[01]----00.0
cd /sys/bus/pci/devices
I find 2 directories, 0000:00:00.0 and 0000:01:00.0.
In 0000:00:00.0, 1 is written in msi_bus.
In 0000:01:00.0, msi_bus is empty.
BR,
Taira
Hi Taira,
Thank you for the reply, I will check on this and update if there is any finding.
rgds,
wb
Hi Taira,
What is the exact ixgbe version used and please try out latest latest version in sourceforge https://sourceforge.net/projects/e1000/files/?source=navbar
Please feel free to update me.
rgds,
wb
