- Email to a Friend
Good time.
We experince link flapping while connecting two supermicro servers with 82599ES adapters:
[Wed Jan 6 07:10:14 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Down[Wed Jan 6 07:10:15 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[Wed Jan 6 07:10:15 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Down
[Wed Jan 6 07:10:16 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[Wed Jan 6 07:10:16 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Down
[Wed Jan 6 07:10:17 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Down
[Wed Jan 6 07:10:17 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
So we are trying to connect two supermicro servers with E10G42BTDA X520-DA2 controller in each server:
81:00.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
In one controller there is following SFP module:
# ethtool --module-info enp129s0f1Identifier : 0x03 (SFP)
Extended identifier : 0x04 (GBIC/SFP defined by 2-wire interface ID)
Connector : 0x07 (LC)
Transceiver codes : 0x20 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Transceiver type : 10G Ethernet: 10G Base-LR
Encoding : 0x06 (64B/66B)
BR, Nominal : 10300MBd
Rate identifier : 0x00 (unspecified)
Length (SMF,km) : 20km
Length (SMF) : 20000m
Length (50um) : 0m
Length (62.5um) : 0m
Length (Copper) : 0m
Length (OM3) : 0m
Laser wavelength : 1330nm
Vendor name : GIGALINK
Vendor OUI : 00:90:65
Vendor PN : GL-OT-ST12LC1-13
Vendor rev : A
Optical diagnostics support : Yes
Laser bias current : 37.020 mA
Laser output power : 0.9654 mW / -0.15 dBm
Receiver signal average optical power : 0.4904 mW / -3.09 dBm
Module temperature : 44.23 degrees C / 111.61 degrees F
Module voltage : 3.2836 V
Alarm/warning flags implemented : Yes
Laser bias current high alarm : Off
Laser bias current low alarm : Off
Laser bias current high warning : Off
Laser bias current low warning : Off
Laser output power high alarm : Off
Laser output power low alarm : Off
Laser output power high warning : Off
Laser output power low warning : Off
Module temperature high alarm : Off
Module temperature low alarm : Off
Module temperature high warning : Off
Module temperature low war...
- Email to a Friend
Hi pva,
Thank you for the post. You are right we recommend to use supported fiber module such as
the one posted on this website
http://www.intel.ph/content/dam/doc/product-brief/ethernet-sfp-optics-brief.pdf http://www.intel.ph/content/dam/doc/product-brief/ethernet-sfp-optics-brief.pdf. Currently,
I do not have information about WDM fiber module for this NIC.
If the 82599 NIC is an onboard NIC on your Supermicro* system, you may check with them
to better assist you about onboard NIC. Thank you.
rgds,
wb
