Ethernet Products
Intel® Ethernet products and technologies
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
3924 Discussions
ixgbe: link flapping on two directly connected servers with 82599ES adapter
Community Manager
Good time.
We experince link flapping while connecting two supermicro servers with 82599ES adapters:
[Wed Jan 6 07:10:14 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Down
[Wed Jan 6 07:10:15 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[Wed Jan 6 07:10:15 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Down
[Wed Jan 6 07:10:16 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[Wed Jan 6 07:10:16 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Down
[Wed Jan 6 07:10:17 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Down
[Wed Jan 6 07:10:17 2016] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
So we are trying to connect two supermicro servers with E10G42BTDA X520-DA2 controller in each server:
81:00.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
In one controller there is following SFP module:
# ethtool --module-info enp129s0f1
Identifier : 0x03 (SFP)
Extended identifier : 0x04 (GBIC/SFP defined by 2-wire interface ID)
Connector : 0x07 (LC)
Transceiver codes : 0x20 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Transceiver type : 10G Ethernet: 10G Base-LR
Encoding : 0x06 (64B/66B)
BR, Nominal : 10300MBd
Rate identifier : 0x00 (unspecified)
Length (SMF,km) : 20km
Length (SMF) : 20000m
Length (50um) : 0m
Length (62.5um) : 0m
Length (Copper) : 0m
Length (OM3) : 0m
Laser wavelength : 1330nm
Vendor name : GIGALINK
Vendor OUI : 00:90:65
Vendor PN : GL-OT-ST12LC1-13
Vendor rev : A
Optical diagnostics support : Yes
Laser bias current : 37.020 mA
Laser output power : 0.9654 mW / -0.15 dBm
Receiver signal average optical power : 0.4904 mW / -3.09 dBm
Module temperature : 44.23 degrees C / 111.61 degrees F
Module voltage : 3.2836 V
Alarm/warning flags implemented : Yes
Laser bias current high alarm : Off
Laser bias current low alarm : Off
Laser bias current high warning : Off
Laser bias current low warning : Off
Laser output power high alarm : Off
Laser output power low alarm : Off
Laser output power high warning : Off
Laser output power low warning : Off
Module temperature high alarm : Off
Module temperature low alarm : Off
Module temperature high warning : Off
Module temperature low war...
st4
New Contributor III
Hi pva,
Thank you for the post. You are right we recommend to use supported fiber module such as
the one posted on this website
http://www.intel.ph/content/dam/doc/product-brief/ethernet-sfp-optics-brief.pdf http://www.intel.ph/content/dam/doc/product-brief/ethernet-sfp-optics-brief.pdf. Currently,
I do not have information about WDM fiber module for this NIC.
If the 82599 NIC is an onboard NIC on your Supermicro* system, you may check with them
to better assist you about onboard NIC. Thank you.
rgds,
wb
