Ethernet Products
5771 Discussions
mi internet no sirveeeeeeeeee
ayudaaa
me dieron un internet de 5g que serian entre 100 a 300 Mbps pero solo da entre 2 a 15 esto es una mierdaaaaaaa
Poojitha
Hi ayudaaa,
Thank you for reaching out to the Intel support. We acknowledge receipt of your concern and want to assure you that assisting you is our top priority. To effectively troubleshoot the issue you're facing, we require some additional information from your end.
Could you kindly provide the following details?
1. Complete ethernet card model details:
2. Kindly elaborate the issue you are facing?
Your prompt response with this information will greatly assist us in diagnosing and resolving the issue as quickly as possible.
We look forward to hearing from you soon.
Poojitha
Poojitha
Hi ayudaaa,
Greetings for the day!
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
We appreciate your understanding!
Poojitha
Poojitha
Hi ayudaaa,
Poojitha
