Ethernet Products
5601 Discussions
multicast doesn't work properly with ixgbevf
YMuna
I'm working on virtual router evaluation with SR-IOV now. My virtual router cannot speak and has proper OSPF relation with external box. Does anyone know how to look into the synopsis deeper? Here are my setup.
1. CSR1K, Cisco virtual router which is running over a server box speaks with an external box
2. SR-IOV is enabled on the server
3. the external box speaks with CSR1K, that means OSPF neighbor has been established
4. CSR1K cannot speak with the external box, it looks that CSR1K cannot recieve any MC/BC packet
5. ethtool shows ixgbe is running with 4.0.1-k-rh7.1, ixgbevf is running with 2.12.1-k
Any input would help me out.
Thanks in advance,
Yuichiro
st4
New Contributor III
Hi Yuichiro,
Thank you for the post. What is the exact network adapter model used here? What is that external box you refer?
rgds,
wb
YMuna
Thank you very much for your attention to my post.
Here are information you pointed out.
- lspci -vvv prints 82599ES 10-Gigabit SFI/SFP+ revisoin 01.
- external box is Brocade MLX-e.
Hope your help a little to figure out my setup.
Yuichiro
YMuna
The driver was replaced with 4.1.2 for ixgbe results in the synopsis I posted has gone. It seems the synopsis has been solved.
Yuichiro
st4
New Contributor III
Hi Ymunakata,
Thank you for the update. I am glad the synopsis has been fixed.
rgds,
wb
