hi,
we have 2 intel 82850 in my Oracle Linux 5.9. but 1 nic's firmware version is 3.0 and another nic's firmware version is 3.9. we want to upgrade firmware with same version, then bonding them.
my question is : where can i download the firmware of Intel 82850 which version is 3.9??
[root@sfsdb5 ~]# lspc |grep net
-bash: lspc: command not found
[root@sfsdb5 ~]# lspci |grep net
04:00.0 Ethernet controller: NetXen Incorporated NX3031 Multifunction 1/10-Gigabit Server Adapter (rev 42)
04:00.1 Ethernet controller: NetXen Incorporated NX3031 Multifunction 1/10-Gigabit Server Adapter (rev 42)
04:00.2 Ethernet controller: NetXen Incorporated NX3031 Multifunction 1/10-Gigabit Server Adapter (rev 42)
04:00.3 Ethernet controller: NetXen Incorporated NX3031 Multifunction 1/10-Gigabit Server Adapter (rev 42)
05:00.0 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
05:00.1 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
05:00.2 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
05:00.3 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
08:00.0 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
08:00.1 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
08:00.2 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
08:00.3 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
Hi Francis11China,
Thank you for posting in Wired Ethernet Community.
I'm currently checking your concern and will update this thread as soon as possible.
regards,
Vince
hi,
any update? thanks!
Hi Francis11China,
Initial checking indicates the firmware of 82580 is not available, since this is an Ethernet Controller integrated to the system, please try to check with your system manufacturer.
On my end, I'll try to check further and post the update in this thread.
regards,
Vince
hi,
we got answer from HP.com, please help to verify it HP said the firmware appear to be "locked" by Intel??
InformationEnd-user unable to find the firmware for HP NC365T PCI Express Quad Port Gigabit Server Adapter installed in HP ProLiant DL380p Gen8 and HP ProLiant ML350 Gen8 Servers.
Intel cards have different firmware revision's shipped from factory itself and HP does not have a public download for this firmware.
There may be different versions of the embedded Intel firmware/EEPROM images for the same NC365T card.
The firmware versions appear to be "locked" to the PCA# type in the NC365T and its date of manufacture.
Hi FrancisChina,
I'd suggest to contact HP support. They might be able to assist you by checking internal channels for the firmware file or provide other options to meet your needs.
regards,
Vince
hi
could you answer it directly?
The firmware versions appear to be "locked" to the PCA# type in the NC365T and its date of manufacture. yes or no?
HP had answer before:
Hi Francis11China,
We're not certain what HP meant by "locked". If they mean firmware shipped with the HP NC365T does not change, then most probably, the answer is "yes" because we don't have the firmware file available.
You've mentioned "bonding" in your initial post, please share additional details in case you encountered issue with your "bonding" configuration.
regards,
Vince
[root@sfsdb4 network-scripts]# cat ifcfg-eth0
# Intel Corporation 82580 Gigabit Network Connection
DEVICE=eth0
BOOTPROTO=none
HWADDR=F4:CE:46:A5:22:60
ONBOOT=yes
USERCTL=no
MASTER=bond0
SLAVE=yes
[root@sfsdb4 network-scripts]# cat ifcfg-eth4
DEVICE=eth4
BOOTPROTO=none
HWADDR=AC:16:2D:98:F2:D0
ONBOOT=yes
USERCTL=no
MASTER=bond0
SLAVE=yes
Hi Francis11China, Thanks for sharing your eth0 and eth4 configuration, please let us know if you have issue encountered with the bond.
regards,
Vince
Hi Francis11China, we'd like to follow-up the issue you've encountered with the bond configuration. Thanks.
regards,
Vince
