Ethernet Products
5534 Discussions
network accelaretion
DCohe5
hi.
can i use PCI EXPRESS INTEL QUAD LAN CARD 10/100/1000 Intel® Ethernet Server Adapter I350T4-V2 on windows 10 computer to accelerate the network comunication to the router?
Hi Dudu.comp,
Thank you for posting in Wired Ethernet Communities. Normally, there are many factors that affect the performance of the network. Let's say if you are using a 100 Mbps network card, and your router supports 100 Mbps and Gigabit speed. Certainly it is a good idea to use a network adapter that can support the maximum speed the router supports if you want to have faster speed. You may refer to the technical specification of I350-T4-V2 at https://ark.intel.com/products/84805/Intel-Ethernet-Server-Adapter-I350-T4V2 and please check with your PC vendor if this network adapter is compatible with your Windows 10 PC.
Please share more information in case you need clarifications. Thank you.
Sharon T
Intel Customer Support
Agent under contract to Intel
Hi Dudu.comp,
Please share more information about your setup in case you need clarifications. Thank you.
Sharon T
