Ethernet Products
5821 Discussions
nvmupdate on X710-da4 fails
MFuck1
I have 6 identical systems with X710-DA4. 4 came with NVM 4.42 and could be upgraded to 5.04 without Problems. 2 have 4.53 and when trying to update, I get: Device not found. Is there a way to downgrade to 4.42 first so I could install 5.04?
test186:~/Linux_x64 # ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.26.17.11
Copyright (C) 2013 - 2016 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [|.........]
Num Description Device-Id B:D Adapter Status
01) Intel(R) Ethernet Converged Network Ad 8086-1572 02:00 Update not available
02) Intel(R) I210 Gigabit Network Connecti 8086-1533 03:00 Update not available
03) Intel(R) I210 Gigabit Network Connecti 8086-1533 04:00 Update not available
Tool execution completed with the following status: Device not found
Press any key to exit.
test186:~/Linux_x64 # uname -a
Linux test186 4.7.0-27-default # 1 SMP PREEMPT Fri Jul 29 16:12:58 CEST 2016 x86_64 x86_64 x86_64 GNU/Linux
test186:~/Linux_x64 # modinfo i40e
filename: /lib/modules/4.7.0-27-default/kernel/drivers/net/ethernet/intel/i40e/i40e.ko
version: 1.5.16-k
license: GPL
Hi molli123,
While we're still checking for the downgrade file and procedure, kindly share the Ethtool -i output of your 2 X710-DA2 with FW 4.53.
Vince
Sorry molli123, should be X710-DA4.
regards,
Vince
MFuck1
I just got help from another side of intel how to modify my cfg-file to successfully upgrade to 5.02- and I haeard a fixed nvmupdate package is on the way.
Thanks for your help,
Michael!
