Ethernet Products
5821 Discussions
on the older Intel 82599/82599ES, I want to know if the latest chipset X710 is compatible and where to check this internally
Reddappaga_R_Intel
Mike_Intel
Hello RRedd4,
For us to further assist you, we need to clarify your exact inquiry.
Please clarify the following details.
  1. Are you going to upgrade upgrade the system with 82599 Ethernet controller to X710 Ethernet controller?
  2. Are you asking if the latest X710 Ethernet is compatible on your existing system?
  3. Are you going to install the latest Ethernet card by yourself?
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
Reddappaga_R_Intel
Hi Please find my answers below. This is the query I got from our customer. Best Regards hari
Reddappaga_R_Intel
  1. Are you going to upgrade upgrade the system with 82599 Ethernet controller to X710 Ethernet controller? NO
  2. Are you asking if the latest X710 Ethernet is compatible on your existing system? Yes
  3. Are you going to install the latest Ethernet card by yourself? Partner HPe
Mike_Intel
Hello RRedd4,
I am sorry, I cannot see the answer from your customer. Can you post it again?
Michael L.
Mike_Intel
Hello RRedd4,
Just want to make a follow up on the information that I requested.
Michael L.
Mike_Intel
Hello RRedd4,
Thank you for the confirmation. Since you have an existing system, the compatibility will be dictated by the motherboard. The board should have a list of its supported components. In this case, if you want to further clarify, please contact the manufacturer of the system to check the compatibility.
Michael L.
Mike_Intel
Hello RRedd4,
I just want to check if you already tried contacting the manufacturer of the board or your system to check the compatibility.
Michael L.
Caguicla_Intel
Hello RRedd4,
Good day!
Please be informed that we will now proceed in closing this request since we haven't received any response from our previous follow up. Should you have any other concern or assistance needed from Intel Ethernet team, feel free to post a new question.
Crisselle C.
