Connection Status : Failed This test relies on a response from a gateway, DNS, DHCP, or WINS server and no such response was received.
Any such server for this connection may be unavailable or misconfigured.
This adapter is configured to obtain an IP address automatically but no DHCP server is present on the network.
Windows selected an IP address using Alternate Private IP Addressing.
Cable Link Status : Failed
Link speed: 100Mbps. The link partner is not capable of higher speeds.
Hi Abhilash_Karne,
Thank you for the post. Can you share more information what is your network adapter model? Based on the result of the connection test, there is problem with your network adapter, have you tried changing the cable? or test the connection on other switch?
wb
Hi Abhilash_Karne,
Can you share the information on my previous post so that I can further check on this.
thanks
wb
