Bonjour,
impossible d'installer Intel Driver & Support Assistant à chaque tentative il y a la fenêtre suivante :
Pourtant Microsoft Visual C++ 2015-2017-2019-2022 est installé.
SVP, pouvez-vous m'aider
Cordialement
Galatoni
- « Previous
- 1
- 2
- Next »
Hello Galatoni,
Thanks for the confirmation, I will proceed to investigate this with the information already provided.
As soon as I have any details I will let you know.
Deivid A.
Hello Galatoni,
Thanks for your patience. In order to continue with the investigation, I would appreciate it if you provide the verbose _000_ logs (Example: installer_log,txt_000_DriverSupportAssistantInstaller.log).
These verbose logs are available at 2 locations:
- C:\Windows\Temp
- C:\Users\{you_user_name}\AppData\Local\Temp
Also, please try to install the VC++ manually from this link and let me know if the issue persists:
Deivid A.
Bonjour et merci,
je joins à ce message les fichiers *.log que me demandez.
le fichier VC++ n'a pas pu s'installer, mais comme je l'ai écrit il est déjà installé.
Cordialement
ANGLAIS :
Hello and thank you,
I am attaching to this message the *.log files that I have requested.
the VC++ file failed to install, but as I wrote it is already installed.
cordially
Hello Galatoni,
I do appreciate all the information provided. I will continue with the investigation and will inform you as soon as I have any details.
Thanks for your time.
Deivid A.
Hello Galatoni,
After the investigation and checking the logs sent, seems to be that the issue is related to Windows rather than the Intel® Driver & Support Assistant (Intel® DSA).
My recommendation is to check with Microsoft to confirm if is possible to properly install the Visual C++ or if is needed a reinstallation of the operating system.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
Bonjour et merci beaucoup d'avoir étudié mon problème et pour le temps que vous m'avez consacré pour essayer de m'aider.
Cordialement
ANGLAIS :
Bonjour et merci beaucoup d’avoir étudié mon problème et pour le temps que vous m’avez consacré pour essayer de m’aider.
Cordialement
- « Previous
- 1
- 2
- Next »
