Ethernet Products
5586 Discussions
problem of installing the igb-5.3.3.10 driver
wli24
hello all:
I am receiving the follwoing error when I installed the igb-5.3.5.10
[ 2617.676535] igb 0000:04:00.0: The NVM Checksum Is Not Valid
[ 2617.702549] igb 0000:04:00.1: The NVM Checksum Is Not Valid
[ 2617.728535] igb 0000:04:00.2: The NVM Checksum Is Not Valid
[ 2617.754518] igb 0000:04:00.3: The NVM Checksum Is Not Valid
Linux version 3.10.0-327.el7.x86_64
CentOS Linux release 7.2.1511 (Core)
Please provide troubleshooting steps.
thanks.
Hi Linuq,
Thank you for posting at Wired Communities. Can you share what is the network adapter model?
sharon
wli24
HI,
Thank u for answering.The model is 82580EB.
regards
Hi Linuq,
Thank you for the information. 82580EB is the Ethernet controller, is this an onboard NIC or a standalone network adapter like I340 ? Have you tried reflash the bootagent by downloading the file below at https://downloadcenter.intel.com/download/19186 in case this is an I340 standalone NIC. You may refer to this 3rd party link for reference which is some what similar case :
http://mynixworld.info/2012/12/05/e1000e-the-nvm-checksum-is-not-valid/
If it is an onboard NIC, please check with the system vendor how you can reflash the NIC.
However, please be informed this is a third party website which is not of Intel's, the content therein is not control by Intel, we do not have control over the suggestion provided. Thank you.
sharon
Hi Linuq,
Please feel free to update me if further assistance needed still?
sharon
wli24
hi,
sry. I am busy recently, so I forgot to reply. I have solved it. I changed the return value in the source code,and it works.
Thank u very much.
Hi Linuq,
Thank you for the update and glad the issue is resolved. Can you share what is the source code portion you changed? Thanks.
sharon
