Ethernet Products
4811 Discussions
problem with intel 218-v
aSila2
I have a asrock h94 pro4 motherboard with a intel 218-v on it.
The problem i have is that i can't get my full internet speed. (50/5)
On the other laptop that i have, there is no such problem, getting my full speed both via wifi and lan, with the cable that i use for my pc, so its not a cable problem or ISP.
Latest drivers installed.
Is there anything that i'm missing?
Thank you.
SYeo3
Valued Contributor I
Hi siralex,
Thank you for contacting Intel.
Here are some recommended settings to improve the adapter's performance:
- Reduce Interrupt Moderation Rate to Low, Minimal, or Off
- Increase the Transmit Descriptors buffer size. The default is 256. Maximum value is 2048.
- Increase the Receive Descriptors buffer size. The default is 256. Maximum value is 2048.
Please try to disable the offloading settings too.
- Offload TCP Segmentation
- TCP Checksum Offload
- UDP Checksum offload
You may refer to website below for more information:
http://www.intel.com/support/network/sb/CS-025829.htm Network Connectivity — Tuning Intel® Ethernet Adapter Throughput Performance
http://www.intel.com/support/network/sb/cs-025841.htm Network Connectivity — Advanced Settings for Intel® Ethernet 10/100 and Gigabit Adapters
I hope this help improve your LAN connection.
Sincerely,
Sandy
SYeo3
Hi siralex,
Sincerely,
Sandy
aSila2
thank you for the help
getting my full internet speed connection now
