Ethernet Products
5736 Discussions
"Interrupt Status Failed" and "The adapter is configured to force the speed to a low speed" I219-V
Zborek
I just tested my ethernet with Intel PROset Adapter Configuration Utility 26.2.0.1 and there is one error (Interrupt Status :Failed) and one thing that i want to change but dont know how (The adapter is configured to force the speed to a low speed.) I am using msi z390 gaming plus. Ethernet in one room is 30mbs and in other 4mbs (speedtest on steam). Does anybody know what to do in that situation?
Thanks in advance and have a nice day.
IntelSupport
Community Manager
Hello Zborek,
Since you are using the Intel Ethernet I219-V which is prebuilt with MSI-Z390. Kindly contact the Original Equipment Manufacturer(OEM) - MSI for further information on this.
The OEM usually have a different configuration or version with the drivers. Please check below link for the latest driver:
https://www.msi.com/Motherboard/Z390-A-PRO/support#driver
May I know if you are using the latest version of Intel Pro Set Utility? Else if no, please try to update to the latest version and check if you are still facing the same issue.
Kindly let us know if you have any questions.
Hayat
Intel Customer Supprt
Zborek
I yesterday updated the drivers from msi site for my mobo, that's why I found this error. One more funny thing is that this app shows that my ethernet cable is 255m long when it is 2m from router and about 10 from main one.
Have a nice day!
IntelSupport
Community Manager
Hello Zborek,
May I know if you have contacted the OEM - MSI for the issue?
Hayat
Intel Customer Support
Zborek
I didn't, I'll do it right now.
IntelSupport
Community Manager
Hi Zborek,
Kindly update us with the feedback provided by MSI here as well.
Thank you.
Hayat
Zborek
After a short conversation they recommend to change ethernet cable, so as soon as i will get home i will try doing it.
Zborek
Guess what happened? Replaced cable and nothing happened, even tried to change rooms. Nothing helped. Now I dont know what to do.
Have a good day
IntelSupport
Community Manager
Hello Zborek,
May I know if you had informed the OEM about this?
Kindly check on Intel® Ethernet Connection I219-V Connection Issue. Please install the driver from the OEM instead of Intel Site drivers.
Kindly let us know the update.
Thank you.
Hayat
Zborek
Yes I contacted MSI, they suggested to change the cable.
I recently updated lan drivers from OEM. I'll uninstall them and do a clean install.
Zborek
Done what i had to do but everything is still the same. Maybe some program was blocking. Started pc in safe mode with Ethernet and still the same. This may be broken port, but not in pc and laptop. I don't know what is going on. On amd it is 30mbs but on two intel devices steam speed is only 4mbs
Irwan_Intel
Hello Zborek,
Could you please try manually setting "Speed & Duplex" to "1Gbps Full Duplex" in Ethernet Controller's "Properties" => "Advanced"-tab, clicking "OK", AND then unplugging the cable, waiting 10 seconds, and plugging it back in.
Irwan_Intel
Zborek
Sorry for responding that late but i just forgot about it. Tested it just a moment ago, in 1gbps full duplex it doesn't work. Just there is no connection, disconnecting and connecting again does nothing. I thing i will just leave it just as it is. Msi support gave up too.
Have a nice week and thanks for help!
IntelSupport
Community Manager
Hello Zborek,
We are sorry to hear that.
We would like you to please check the link below for a very similar case which might help you.
https://community.intel.com/t5/Ethernet-Products/Intel-R-Ethernet-Connection-12-I219-V-disconnects-randomly/td-p/1483062
Kindly check and update us on this. We will keep this thread open for the next 3 days to wait for your update on this. Else if no replies, we will proceed to close the thread.
Please check and let us know.
Thank you.
Hayat
Zborek
Tried doing thing from the topic you send me but there are no changes. Tried with same pc but on linux and the ethernet is same speed as on amd pc. So reinstalling os is the sollution, probably, but i think that i wont do it, i have too much things that i might need one time. Thanks for fast help and just for help. You can close the topic.
Regards and thanks again
IntelSupport
Community Manager
Hello Zborek,
Thank you for the confirmation.
Thus, we will proceed to close the thread.
Once the thread is closes, it will no longer be monitored by Intel.
Kindly open a new thread if you need further assistance.
Hayat
