Ethernet Products
4852 Discussions
"No probed ethernet devices" when use Intel Ethernet Server Bypass Adapter X520-SR2 in DPDK 1.7.1
MHoan4
I encountered error message "No probed ethernet devices" when I tried to use Intel Ethernet Server Bypass Adapter X520-SR2 in DPDK 1.7.1 environment (OS: CentOS 7, Server: DELL PowerErge R720).
Can anyone tell me how to use Intel Ethernet Server Bypass Adapter X520-SR2 in DPDK 1.7.1 ?
st4
New Contributor III
Hi MinhMinh,
Thank you for the post. We will further check on this.
rgds
wb
st4
New Contributor III
Hi MinhMinh,
Can you help provide lspci dump and find out if the same behavior exist from testing a second card (in case there is spare one) to test.
thanks,
wb
st4
New Contributor III
Hi Minhminh,
Please feel free to provide lspci dump and check if the same behavior exist if you have a second card to test.
thanks,
wb
