Ethernet Products
5736 Discussions
"PF reset" error on i40e driver and XXV710 card
jalbe15
hi
xxv710 card up/down Repeatedly on ubuntu 16.04 kernel: 4.15.0 and generate below message in syslog
i40e version: 2.7.29
netmap capture version: 13.0
syslog error:
kernel: i40e 0000:01:00.1: TX driver issue detected, PF reset issued
AlfredoS_Intel
Hi Jalbe15,
Thank you for posting in our Intel® Ethernet Communities Forum.
We need to gather information so we can provide you recommendations.
Please provide the exact model of the card that you are experiencing an issue with.
Looking forward to your response. Should we not get your reply, we will follow up with you after three business days.
Alfred S
Intel® Customer Support
AlfredoS_Intel
Hi Jalbe15,
We have not heard from you yet, and we are reaching out to check if you need more time.
Should we not get your response, we will check back with you again after 3 business days.
If there is still no response, we may be forced to close the thread.
Alfred S
Intel Customer Support
jalbe15
thanks for your cooperation
Please wait a moment
AlfredoS_Intel
Hi Jalbe15,
No problem.
We will wait for your post. Should we not hear from you, we will check back with you after 3 business days to check if you need more time.
Alfred S
jalbe15
Thanks a lot
ethernet Card specifications with command "lshw" :
lshw -class network
 *-network:1 DISABLED
    description: Ethernet interface
    product: Ethernet Controller XXV710 for 25GbE SFP28
    vendor: Intel Corporation
    physical id: 0.1
    bus info: pci@0000:82:00.1
    logical name: eth5
    version: 02
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi msix pciexpress bus_master cap_list ethernet physical autonegotiation
    configuration: autonegotiation=off broadcast=yes driver=i40e driverversion=2.7.29 firmware=6.80 0x80003d05 1.2007.0 latency=0 link=no multicast=yes
    resources: irq:16 memory:c9000000-c9ffffff memory:ca008000-ca00ffff memory:3bfff500000-3bfff8fffff memory:3bfffd00000-3bfffdfffff
AlfredoS_Intel
Hi Jalbe15,
We appreciate the time that you took out of your busy schedule to share that information.
We will continue investigating your concern, and we will give you an update no later than 3 business days from now.
We may need to ask for more information during the investigation process.
Alfred S
AlfredoS_Intel
Hi Jalbe15,
Please allow us more time to check on your concern. We would like to get some information from you to aid us in our investigation. Please provide us the results of this command:
"ethtool -i"
Alfred S
jalbe15
Hi AlfredS_Intel
driver: i40e
version: 2.7.29
firmware-version: 6.80 0x80003d05 1.2007.0
expansion-rom-version:
bus-info: 0000:82:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
AlfredoS_Intel
Hi Jalbe15,
Thank you for that additional information.
Just to ask, have you already tried upgrading the NVM of the ethernet card? Please note that upgrading the NVM of an ethernet card only works with intel distributed retail cards.
Looking forward to your reply. Should we not get your reply, is it okay if we will check back you after 3 business days
Alfred S
jalbe15
Thanks a lot
We haven't updated yet
AlfredoS_Intel
Hi Jalbe15,
Thanks for your swift response.
We need to double check first if updating the NVM of your card will help with your issue.
Please allow us some time to do so. We will get back to you no later than 3 business days from now.
Alfred S
AlfredoS_Intel
Hi Jalbe15,
Thank you for patiently waiting.
After some checking, we would recommend you to please update the NVM of your card to the latest version.
Please let us know of the results after doing it.
Should we not hear from you, we will check back with you after 3 business days.
Alfred S
AlfredoS_Intel
Hi Jalbe15,
If there is still no response until that time, our system may consider automatically closing this thread
Alfred S
AlfredoS_Intel
Hi Jalbe15,
We are following up on your thread that is still open where you are asking assistance for PF reset issues that you are experiencing with your ethernet card. We know that this is important for you to get your issue resolved and it is also equally important for us to see to it that it is already fixed. Since we have not heard from you for several days, the case will automatically close.
You may want to post a new thread once you are ready to proceed with the issue.
Thank you for choosing Intel.
Alfred S
