Ethernet Products
5223 Discussions
remove vlan tag by ethtool
daniel-payne
hi everybody
is there anyway to accept a traffic with vlan tag by ethtool and the remove the tag from the packet on i40e prodcut?
for example this is the command i used
ethtool -U eth1 flow-type tcp4 vlan-id 100 action 4
now that i have targeted vlan 100 packets is there anyway to remove the tag from it and redirect the traffic somewhere else without vlan tag?
i would be so grateful if you coud help
tnx everyone
Sazirah
Hi daniel-payne,
Regarding your issue, for us to check on any resolution, can you share with us the Intel Ethernet device model that you are using?
Sazzy_Intel
daniel-payne
hi sazira
thank you for your reply
I'm using intel x710 . driver i40e 2.23.17 . firmware-version 7.20.
Sazirah
Hi daniel-payne,
Thank you for your reply.
Regarding this issue,  we need your assistance to provide us the SSU logs of the device. The Intel® System Support Utility (SSU) scans for system and device information to assist with customer support troubleshooting. Please refer link below for the steps to obtain the SSU logs:
Help Guide for the Intel® System Support Utility
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
Once you obtain the SSU logs as instructed in the link above, please share with us for us to analyze the log and assist you further.
If you have any enquiry about this, please let me know.
Sazzy_Intel
Sazirah
Hi daniel-payne,
Good day,
This is related to your enquiries above, I would like to check if the issue has resolved? If no, please help to obtain the SSU logs as advised above and kindly share with us the logs for us to investigate on the issue.
If you have any questions or clarifications, please let me know.
Sazzy_Intel
Sazirah
Hi daniel-payne,
Good day,
I would like to follow up if you have any questions or clarifications regarding this case.
Feel free to contact us should you need any further assistance, and we will be more than glad to continue assisting you.
Sazzy_Intel
Sazirah
Hi daniel-payne,
Good day.
This is regarding your enquiry above.
Since we have not seen an update, we will be closing this forum case from our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
