we are curently facing an issue to implement round-robin bond configuration in our VM with SR-IOV and XXV710 network card.
On the compute which hosting the VM, there are 2 intel XXV710 network cards (2 ports for each card)
So, there are 4PF. And for each PF, there are 4 VF as the bellow output is showing :
9: enp94s0f0: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 9000 qdisc mq portid 3cfdfeca9c84 state UP mode DEFAULT qlen 1000
link/ether 3c:fd:fe:ca:9c:84 brd ff:ff:ff:ff:ff:ff
vf 0 MAC 00:00:00:00:00:00, spoof checking on, link-state auto, trust off
vf 1 MAC 00:00:00:00:00:00, spoof checking on, link-state auto, trust off
vf 2 MAC 00:00:00:00:00:00, spoof checking on, link-state auto, trust off
vf 3 MAC fa:16:3e:20:db:58, spoof checking on, link-state auto, trust off
10: enp94s0f1: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 9000 qdisc mq portid 3cfdfeca9c85 state UP mode DEFAULT qlen 1000
link/ether 3c:fd:fe:ca:9c:85 brd ff:ff:ff:ff:ff:ff
vf 3 MAC fa:16:3e:5e:26:c7, spoof checking on, link-state auto, trust off
11: enp216s0f0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq portid 3cfdfeca9fbc state UP mode DEFAULT qlen 1000
link/ether 3c:fd:fe:ca:9f:bc brd ff:ff:ff:ff:ff:ff
vf 3 MAC 00:00:00:00:00:00, spoof checking on, link-state auto, trust off
12: enp216s0f1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 qdisc mq portid 3cfdfeca9fbd state UP mode DEFAULT qlen 1000
link/ether 3c:fd:fe:ca:9f:bd brd ff:ff:ff:ff:ff:ff
For the test, our VM is configured with one VF of enp94s0f0 PF and one VF of enp94s0f1 PF
Bellow is the bond configuration down on the VM :
# cat ifcfg-eth1
DEVICE=eth1
BOOTPROTO=none
ONBOOT=yes
MASTER=bond0
USERCTL=no
SLAVE=yes
NM_CONTROLLED=no
cat ifcfg-eth2
DEVICE=eth2
BOOTPROTO=none
ONBOOT=yes
MASTER=bond0
USERCTL=no
NM_CONTROLLED=no
SLAVE=yes
cat ifcfg-bond0
DEVICE=bond0
ONBOOT=yes
BOOTPROTO=static
USERCTL=no
NM_CONTROLLED=no
BONDING_OPTS="mode=0 miimon=100 fail_over_mac=active"
cat ifcfg-bond0.3304
DEVICE=bond0.3304
NAME=bond0.3304
BOOTPROTO=none
ONPARENT=yes
IPADDR=X.X.X.X
NETMASK=255.255.255.0
GATEWAY=X.X.X.X
VLAN=yes
NM_CONTROLLED=no
And when the command systemctl restart network is launched ... Only one of the two interfaces is enslaved into the bond (not always the same, sometimes eth1, sometimes eth2 ...)
# cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: load balancing (round-robin)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
Slave Interface: eth2
MII Status: up
Speed: 40000 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: fa:16:3e:5e:26:c7
Slave queue ID: 0
For information, we have tried the following commands in the VM (but the result is the same)
ip link set eth2 promisc off
ip link set eth1 promisc off
We have also tried to play with trust / state / promisc / spoofchk / vlan parameter ) as showing the following commands on the compute which hosting the VM (but the result is the same)
for i in 0 1 2 3; do ip link set enp94s0f[0..1] vf $i trust on/off ; done
for i in 0 1 2 3 ; do ip link set enp94s0f[0..1] vf $i state enable/auto; done
for i in 0 1 2 3 ; do ip link set enp94s0f[0..1] vf $i promisc off/on; done
for i in 0 1 2 3 ; do ip link set enp94s0f1 vf $i vlan 0 qos 0 ; done
For information, implementation of an active-backup bond configuration (mode=1) works successully
Hello DNico6,
Please give us time to check on your query. We will give you an update within 2-3 business days.
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
Hello DNico6,
Thank you for the patience on this matter.
Kindly share the driver version used on the PF, VF and Linux OS with kernel information for us to further check on your request.
Crisselle C
Dear Crisselle ,
Please find below the requested informations.
driver version ==>
rpm -qa | grep i40e
i40e-2.7.12-1.x86_64
cat /etc/redhat-release
Red Hat Enterprise Linux Server release 7.4 (Maipo)
uname -a
Linux <hostname>3.10.0-693.35.1.el7.x86_64 #1 SMP Thu Jun 7 07:29:04 EDT 2018 x86_64 x86_64 x86_64 GNU/Linux
Nicolas DEROUIN
Hello DNico6,
Thank you for providing the driver version.
By the way, can you confirm if you are using on-board NIC or PCIe NIC?
Michael L.
Dear Michael,
Thanks for your reply.
We are using PCIe NIC.
Nicolas DEROUIN
Hello DNico6,
Thank you for the confirmation. Can you send photos of both sides of the NIC focusing on the markings?
Michael L.
Hello DNico6,
I tried validating the markings of the network card that you provided and found that this card
is not a retail Intel network card and this card belongs to Cisco. Have you tried checking the issue with Cisco or have you tried to ask them if the have an updated driver for Linux?
If you have questions, please let us know.
Michael L.
Hello Nicolas,
While we are still looking into your query, we'd like to check if you have tried contacting Cisco to check if they have an updated driver for Linux.
Awaiting to your reply.
Crisselle C
Hello Nicolas,
We apologize for the delay on this matter.
Based on the details you have provided, it seems that VF driver version is missing. If the virtual function (VF) driver is lower than 3.7.53, please try the latest version on the link below:
Same with the PF (i40e), try out the latest version 2.9.21 and let us know if updating to latest version was of help to your issue
Crisselle C
Hello Crisselle,
Thank you for your support.
We are actually running RHEL 7.4 kernel version 3.10.0-693.35.1.el7.x86_64
I cannot find any information about kernel version requirement in the notice of the VF driver version 3.7.53 : https://downloadmirror.intel.com/24693/eng/readme.txt
Would please confirm that the version 3.7.53 is compatible with this kernel version ?
Georges DAMIEN
Hello Geroges,
We appreciate your reply.
Please allow us to check on this further and we'll give you an update within 1-3 business days.
Hoping for your patience.
Crisselle C
Hello Geroges,
Please be informed that we are still looking into your query. Rest assured that we will provide an update within 1-3 business days.
We appreciate your patience.
Crisselle C
Hello Geroges,
After further checking, it is best to try the channel bonding configuration in kernel version 4.x and up with i40e driver (2.9.21) and iavf driver (3.7.53) as there are many features from kernel 3.10 that has been backported by Red Hat which hardly resemble the actual versions release from kernel.org.
Let us know if you have additional questions and clarifications.
Crisselle C
Hello Geroges,
We'd like to check if you were able to try the latest i40e driver (2.9.21) and iavf driver (3.7.53). Kindly share the results after trying it out.
Crisselle C
I've tested the iavf driver 3.7.53 on rhel7.4 (kernel=3.10.0-693.el7.x86_64).
After the driver installation, the VF interfaces disappeared from the virtual machine.
I guesss it's due to driver/kernel incompatibility.
I'm trying to find out which iavf driver version works with 3.10.0 kernel.
Georges
Hello Geroges,
Thank you for sharing your observation.
We will wait for your update on this matter. But as mentioned above, it is best to try the channel bonding configuration in kernel version 4.x and up with i40e driver (2.9.21) and iavf driver (3.7.53).
We hope you can find iavf driver version that works with 3.10.0 kernel.
Crisselle C
Hello Crisselle,
I have few question about driver versions :
Is there any correlation between the i40e driver version and iavf driver version on both the host and the VM (compatibility matrix)?
Is the iavf driver version has any importance on the host, or what matters is the version inside the hosted virtual machine ?
Georges
Hello Geroges,
Thank you for the reply.
1.) Kindly provide the link for compatibility matrix link that you mentioned for us to look into your query.
2.) Here is our answer for your question number 2.
Whenever virtual functions are created in the host, Virtual Function drivers are loaded. Therefore the VF driver version is also important to the host as updated VF drivers incorporate fixes and additional support.
For sample change log, please refer to the link below:
https://sourceforge.net/projects/e1000/files/i40evf%20stable/3.6.10/
Looking forward to hear from you.
Crisselle C
