Ethernet Products
5821 Discussions
same MAC + different VLANs VFs that comes a PF
I'm using 82599 NIC with SR-IOV technology.
recently I've got an issue with following configuration.
as you can see there are two VFs that has same MAC on one PF. but each VF tagged different vlan. I thought that it should be work. but when after I create vf4, the vf3 is not working.
but vf3 is working when after I remove vf4 without any reboot/recreation operation.
Is there any limitation to use sr-iov (vf) with fixed-mac/vlan that created from a PF? any specific reason or specifications we have?
ip link show eth5
vf 0 MAC 12:00:00:00:03:00, vlan 812, spoof checking on
vf 1 MAC 12:00:00:00:00:50, vlan 812, spoof checking on
vf 2 MAC 12:00:00:00:00:c0, vlan 812, spoof checking on
vf 3 MAC 12:00:00:00:10:c0, vlan 812, spoof checking on
vf 4 MAC 12:00:00:00:10:c0, vlan 810, spoof checking on
Hi Nasaram, i'm currently checking if your issue is related to mac address spoof check. will update this thread as soon as possible.
please share the output of your ethtool -i.
thanks,
vince
Hi Nasaram, VF's are like software NICs, Each needs its own unique MAC address.
Please let us know if you still need additional assistance regarding Intel(R) 82599 NIC and SR-IOV.
regards,
Vince
Hi Nasaram, we'd like to follow-up if you still need assistance regarding Intel(R) 82599 NIC and SR-IOV.
regards,
Vince
