I am trying to image a latitude e5570 with a i219-lm network adapter. The pxe boot fails because the driver i injected into the wim file doesn't correspond. I've tried the manufactor driver and the driver from intel but without result
These are the drivers i tried without succes
i'm using system center version 1602 and where using the x86 boot image.
Does anyone know which driver i should use?
HI D2daniels,
Thank you for the post. Just to double check if this is the drive file you downloaded from Intel website?
https://downloadcenter.intel.com/download/18713/Intel-Network-Adapter-Driver-for-Windows-7-?product=71307
wb
Thank you for your answer. I've downloaded the driver and imported the proxgb drivers. No luck there... so this i double checked
Hi D2daniels,
Thank you for the update and glad the 100 mb driv works for you.
rgds,
wb
