Ethernet Products
5537 Discussions
unable to create VLAN
VermaNishant
I am using CPU
Model name: Intel(R) Xeon(R) CPU D-1581 @ 1.80GHz
with two 10G NIC's
02:00.0 Ethernet controller: Intel Corporation Ethernet Connection X552 10 GbE Backplane
02:00.1 Ethernet controller: Intel Corporation Ethernet Connection X552 10 GbE Backplane
On top of these PF, I created VF's. By taking one VF from each PF, I further created vbond. This is stated in screenshot below. I deliberately down the eno1 interface from the switch.
Problem:
The issue here is when I tried to create the vlan on top of bond0, it works fine. But if I try to execute the same command for vbond, it fails.
If i just flip it and make the eno1 UP and eno2 DOWN, then vlan command for both interfaces, bond0 and vbond works fine.
Below are the configuration for vbond
cat /proc/net/bonding/vbond
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: fault-tolerance (active-backup)
Primary Slave: vnic1 (primary_reselect always)
Currently Active Slave: vnic2
MII Status: up
MII Polling Interval (ms): 10
Up Delay (ms): 0
Down Delay (ms): 0
Slave Interface: vnic1
MII Status: down
Speed: Unknown
Duplex: Unknown
Link Failure Count: 0
Permanent HW addr: XX:XX:XX:XX:XX:XX
Slave queue ID: 0
Slave Interface: vnic2
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 1
Slave queue ID: 0
This is for bond0
cat /proc/net/bonding/bond0
Primary Slave: None
Currently Active Slave: eno2
MII Status: up
Up Delay (ms): 0
Down Delay (ms): 0
Slave Interface: eno2
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 2
Slave queue ID: 0
Any help, why this is not working or any pointer or reference?
IntelSupport
Community Manager
Hello Nishant,
Greetings for the day!!
Thank you for posting in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and would like to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved, or if you require further assistance from us? Your prompt response will greatly help us in diagnosing and resolving the issue as quickly as possible.
We appreciate your patience and understanding, and we look forward to hearing from you soon.
Kuzhanthai Yesu R
IntelSupport
Community Manager
Hello VermaNishant,
This is to follow up on the issue you reported to us.
Could you please confirm if the issue has been resolved or if you still require our assistance? Your timely response will help us diagnose and address the issue more efficiently.
We look forward to hearing from you soon.
Kuzhanthai Yesu R
Yesu27
Hello VermaNishant,
This is the final follow-up regarding the issue you reported to us.
Could you please let us know if the issue has been resolved or if you still need our help? Your prompt response will assist us in diagnosing and addressing the issue more effectively.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Please feel free to respond to this email at your earliest convenience.
Kuzhanthai Yesu R
