I have a cluster of ~150 machines with X520-2 network adapters. What's the easiest way to upgrade the entire cluster to the latest version of the driver? I downloaded PROWinx64.exe which will upgrade an individual machine but with GUI interaction - is there some way to run this binary in an unattended or silent mode?
Rich
Extract the files from the web pack download using winzip, winrar or a similar program.
Here is the command line for installing silently:
\APPS\PROSETDX\Winx64>DxSetup.exe /qn
The installation is completely silent, so you won't see any feedback. I just ran this on my laptop to upgrade the driver, and it worked perfectly. The readme file on the download page has other command line options, but I think the line above is all you will need.
I hope this helps.
Mark H
I hope this helps.
Mark H
